Question about Bushnell Tour V2 Pinseeker Laser Rangefinder
Changed battery wont come back on
I changed the battery and unit will not come back on
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
My ti-83 wont turn on. I changed all the batteries including the back up. Before i changed the back up i put in 4 new AAA batteries and then the screen went black. I tried adjusting the contrast but it...
I am sorry that I could not respond earlier. I am not sure of this but I think you can remove the back up battery and also the main battery, check the cells to see if there was a drain on the new cells , if so there is a short in the unit. If not keep aside for few hours and then replace the back up and then the main cells.
If there is no display there is some issue on the motherboard and might need a consensus.
Oct 26, 2011 | Texas Instruments TI-83 Plus Calculator
Changed the battery with an aftermarket one and unit wont work
Either the touchscreen has failed or you have accidentally disconnected the touchscreen flex cable. Many people break the flex connectors trying to change a battery. The LCD does not need to be disconnected in order to change a battery.
Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Mar 04, 2010 | Garmin Nuvi 660 GPS Receiver
I have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
Nov 14, 2009 | Heating & Cooling
It wont turn on the spinner light wont turn off
10-2009
Had the same problem. I took off the back, removed the battery and put it back in. And, now it's fine. Could be a form of resetting the unit. Found no directions on how to change the battery, I figured the battery was OK and was going to salvage it for another unit, But, now I'm back to 2 Sansa's. Found nothing on google to help with this problem. Good luck
Nov 12, 2009 | Audio Players & Recorders
Fujitsu air con unit. Remote wont work. has new batteries
Check the micro processor control whether it is in manual mode or not. If not check the sensor whether it is functioning or not. If everything is fine then remote control has to be changed.
Aug 15, 2009 | Heating & Cooling
Toshiba satellite a60 wont start.
replace your cmos battery inside... look for a technician for assistance to remove the cmos battery and change a new one... your battery is weak already
Jun 18, 2009 | Toshiba Satellite A60-S1561 Notebook
Wont freeze
When changing the battery it should be a alakline. Also try unplugging the unit and then back in again. Check to see if the sides are getting warm which will indicate the compressor is running. Make sure the compressor is running. Check to see if thermostat is up high enough. The unit may have an electronic board that may be the problem. And lastly, it could have a sealed system problem, like a freon leak. You didn't say how old the unit is.
Aug 30, 2008 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Bushnell Tour V2 Pinseeker Laser Rangefinder Logo
79 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
