Question about Anuman Sudden Strike 3: Arms for Victory for Windows
I pressed a button on the mini tivo and i keep getting finding a tuner. How do i get b ack to Live t.v.
What button do i NEED TO PUSH to get back to using Live T.V.
How do you retune a tivo?
Press TiVo Central button, go to Settings & Messages, Select settings, Select Network, Select connect to TiVo. Let this run. Should connect. If that doesn't work, unplug for 10 seconds and let it try to connect, if it doesn't, follow above steps again. My TiVo mini does this all the time, I love the TiVo features and the idea behind it is great, but the mini is JUNK. Hope this helps.
May 26, 2014 | Televison & Video
Need code to use for the tivo remote
Push the TiVo button on the remote. Then push "Messages and Settings," followed by "Settings," and finally press "Remote Control." This will show you the three areas of the remote that are programmable. "TV Power, Volume and Mute," is one section. "AV Volume and Mute," is the second section. The final section is "TV Input."
Pick "TV Power, Volume, and Mute" by pushing right on the direction pad of the remote. This will open up a list of all the brand names of TV that exist. You will find most TV brands will be there.
Find your brand of television and select that option. If your brand is not there, simply go to the TiVo webpage and under "Setup and Support" you will find others who have experience this issue. There you will find a code for your TV. This happens sometimes when the TV is a lesser known brand.
Hold down the button you are programming (i.e. TV Power) for 5 seconds until the red light on top stays on. Then enter one of the codes on the screen.
Push the newly programmable button to test its functionality. If it does not work, repeat the steps with all the possible codes available. One of the codes will work.
Push "Live TV" at this point to watch television.
Use the manual which came with your TiVo in addition to this guide. In the front of the booklet will be a starter guide, which will lead you through the steps necessary to set up your remote for optimum use.
Mar 23, 2011 | Televison & Video
I have upgraded my comcast service to an extended version including more channels but no cable box. I've been unable to set up my TIVO dual Series device to get the new channels, it only recognizes the...
Try this first...Press the TiVo button at the top center of the Remote, then > Messages & Settings > Restart or Reset System > Repeat Guided Setup and then follow the onscreen instructions from there.
This should load your new channel lineup into your TiVo.
If all the channels are still not recognized... Press the TiVo button at the top center of the remote, then > Messages & Settings > Settings > Channels > Channel List and then make sure all of the channels you receive are checked.
Jun 08, 2009 | Tivo Series2 Dual Tuner Digital Video...
How use Tivo on Motorola DCT6412 III?
this works to record progam you watching
1. press menu key
2. highlight DVR button by using either < or > key then press OK button
3. answer prompts
Do this to set up a recording in advance or a series recording
1. Hit the guide button
2. scroll thru channels until you find program you want to record
3. scrool over to red dot press OK button
4.you can the highlight red dot for one time recording or go down one to record every episode. make sure you check the settings for this program.
Hope this Helps.
Mar 19, 2009 | Motorola Televison & Video
TiVo stops recording
The problem is probably due to lack of available space on your Hard Drive.
Try deleting some programs you have saved as "Keep Until I Delete" and you should then be able to completely record the new programs.
Also, in case you didn't know, Tivo will NOT let you fill up the entire Hard Drive with programs you want to record, but rather, it keeps approx. 30 minutes of Hard Drive space for each tuner as a buffer so that in the case of a show you are watching live, you can go back and replay part of a show you have just seen.
Oct 19, 2008 | Tivo Series2 TCD649080 Video Recorder
Directv DVR vs Tivo
I found the manual for that model online, and according to it, the "Live TV" button should function exactly the same way your old Tivo did.
If it's not working correctly, you may want to contact the manufacturer, assuming it's still under warranty.
Aug 06, 2008 | Hughes HDVR2 with 105 Hrs DirecTV DTV...
Tivo and direct tv
No, unfortunately there is not. That tivo only has 1 tuner, so you can only record or watch 1 live program. You can however watch a pre-recorded program while recording a live program. If you have directv, you can step up and get their hr20 dvr. It's not a tivo by any means, but it has 2 tuners so you can record 2 things at once and watch a pre-recorded show. It takes a little while to get used to the interface, but once you get the hang of it, it's pretty straightforward.
You can also get an older DVR w/ tivo (hr10) however, it will not get ANY of the new MPEG4 High Def channels that are out there.
If you have an hdtv, then you really should grab an hr20, give directv customer retention a call and ask what they can do for you. You'll need a new slimline dish and they'll come out install it and everything you need for watching off the new satellites and enjoying the new mpeg4 hd channels (the old hd channels are in mpeg2).
Good luck.
Dec 12, 2007 | Tivo Series 2 80-Hours Video Recorder
Tivo not working
Looks like you only have one tuner hooked up (one cable ) to your tivo. You need 2 in order to work properly
Oct 28, 2007 | Tivo Series2 TCD649180 DTV Receiver /...
Tivo not working correctly
Cable chanels an dtv chanels are not the same
Anuman Sudden Strike 3: Arms for Victory for Windows Logo
20 people viewed this question
Top Anuman Video Game Consoles & Games Experts
James Wishart
Are you an Anuman Video Game Console and Game Expert? Answer questions, earn points and help others
