Question about Kenmore Elite 45986 Front Load Washer
Kenmore 110.42924200 washer specs. - Kenmore Elite 45986 Front Load Washer
Washer capacity of kenmore 4906 4907 ie 5.0 cu feet
The Kenmore 592-4907 residential clothes washer is a front load washing machine. It has 3.69 cubic feet of volume, an expected energy use of 149 kilowatt hours (kWh) per year and an expected water use of 4773.384 gallons per year.
The Kenmore 592-4906 residential clothes washer is a front load washing machine. It has 3.69 cubic feet of volume, an expected energy use of 149 kilowatt hours (kWh) per year and an expected water use of 4773.384 gallons per year.
This is the Specs website despite the title :>)
teachmefinance com
Mar 24, 2017 | Kenmore Washing Machines
What is the capacity of the kenmore front load washer model 110.42936 200
If you search for the:
Make Model
you should be able to find that information in the "Specs" section.
Jan 07, 2017 | Kenmore Washing Machines
How t fix f25 error code on kenmore washer
I am no tech!! Just a 57 year old grandma, but I replaced my MCU myself by looking at the spec sheet and also asking the people I bought the MCU from. I bought the matching washer/dryer (it was nearly new!) at a moving sale, used it about 5 or 6 times and "BAM!!", it started throwing a code 11. I'm a fixer type, so I started researching the problem. Take the lower front of the washer off and that's where the spec sheet is. Mine was on the right inside, as you are facing the washer. There's some info on what different codes mean. If you google this washer, there's a lot of info as well and in some cases, there's good video on youtube. I got the fix right the first time I tried! It was a little costly though because the MCU was $200 alone. If I had used a repairman, I'm sure it would have been at least twice that much. Good luck and I hope this basic info is helpful.
Jun 18, 2014 | Kenmore Elite HE5t Washer
Washer does not spin
You must replace the direct drive coupling between the motor and transmission. About $30.00
Mar 10, 2009 | Kenmore Washing Machines
What is my washer's capacity?
able to find a spec sheet on your specific washer, but i can tell you that you have a whirlpool made kenmore washer. and at 18 yrs ago they have only gotten larger, youd be hard pressed (unles you bought a apt sized machine or a laundry center) to get a smaller capacity machine. new machines are huge in comparison to the oldies
Oct 26, 2008 | Washing Machines
Capacity
Hi there, I have the same washing machine. since it's 2002, Kenmore does not have the info.. I just called sears and they said the capacity is 3.2 Cu Feet. That translates to 19lbs of clothing.
cheers,
Joel
Aug 01, 2008 | Kenmore 43142 Front Load Washer
Kenmore front Loader 41729042990
remove motor, check carbon brushs,replace if short,the manual may help.motors that have brushs are the principle,sole motor is Italian,yours is German,anyway thats beside the point ,its the brushs.buy ,eire
Dec 11, 2007 | Kenmore 44102 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
109 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
