Question about Danby Designer Series DMW111KPSSDD
Does my dansby model number dmw111kpssdd have a fuse
Doesnt work at all
Smh9187 microwave stopped working. The units display works, light inside works, vent fan works, but when you put food in it doesnt make a sound.
On model SMH9187B and SMH9187ST, one likely cause is a defective bottom door switch (primary interlock) or that switch's mount is loose, misaligned, or broken. The service manuals for these models are at my site here:
SMH9187B service manual
SMH9187W service manual 1 ' service manual 2
SMH9187ST service manual
Also see my help file on door switches here.
You can order Samsung parts by part number from the Pros here.
If it's not a door switch issue, it may be a blown high voltage fuse not to be confused with the line fuse) or a relay issue on the board, which I can repair for you.
If you have other questions, feel free to contact me at my site below for more free help.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 18, 2017 | In Microwave Ovens
Ge profile microwave just stopped working doesnt light up or turn on model pvm2070dmbb
You should first check the outlet with a toaster or hair dryer to be sure it's working under a load.
Then you should test the fuse then the TCOs.
There is a technical sheet hidden behind the grille or controls.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download GE owner's manuals and installation instructions here.
Dec 26, 2013 | GE SpaceMaker Microwave Ovens
Is there a fuse or breaker inside this model.
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line fuse is listed as item 12 (part number 56001353). Keep in mind, there are different vairations on the model number you provided. You need to look at the model number you have and include the last three letters as well. I reviewed most of these models and they appear to all have the same parts. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended. If you wish to order on line, use the part numbers to search by comparison as the model number you listed this question under may not be available at all the websites I have provided. The parts, however, ARE listed.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
May 13, 2010 | Amana AMV5164 Microwave Oven
Microwave turns on but doesn't cook
There is an inline fuse that is accessed by removing the outer casing. Follow the power line in to the magnatron and you should see the fuse. Make sure the fuse that you replace it with is the same as the one you removed. If this doesnt work then the magnatron has gone out.
Dave
Mar 31, 2010 | Kenmore 80012 Microwave Oven
Whirlpool microwave model # MH6150XLQ
Yes, there is. If you go to searspartsdirect.com and type in your model number, you will find the fuse listed under the "Interior Parts" heading as item number 14 (part #815174). You can find appliance fuses much cheaper at the local hardware store. Just make sure it is the correct type and rating (refer to the fuse in the appliance for the information - these are usually a 120V 20A fuse). The reason I mention this site is because they provide excellent part drawings and provide part numbers. There should also be a wiring diagram located behind the control panel to assist you in troubleshooting. Please go to my profile and use the "Ask Me" feature if you require further assistance. I hope this helps you.
Jun 16, 2008 | Microwave Ovens
My microwave doesnt work
Can you see even a colon or dot on the display?
Have you tried it with the door open and closed?
It may be a bad door switch or a door alignment issue, or it may be a problem with the control panel.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with your model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 18, 2008 | Whirlpool MH1150XM Convection/Microwave...
Repair an Amana microwave
My amana micro just went dead. No lights nothing ,almost like a fuse blew.Its an over the stove model . The outlet works fine.#mvh210w
Dec 21, 2007 | Amana AMC6158B 1000 Watts Convection /...
Danby Designer Series DMW111KPSSDD Logo
42 people viewed this question
Top Danby Microwave Ovens Experts
William Miller
William Miller
vince
gbob59
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
