Question about Daikin FTXS24HVJU
Cool air when unit not blowing out warm air and the fan cut out a trickle of cool air flows
Air conditioning unit blowing warmer air even when unit is set on 70 and then will blow for 10-15 minutes and then cut off for 5-10 minutes before coming back on again blowing warm air.
If its a window unit, pull out of window get to the front fins might have to remove a few screws on the sides of front and spray out with a hose be careful not to get control box wet.spray fins and wheel inside, dump water out the back or side, put back in window it should start blowing cold air if not then its time for a new one.but sounds like its getting over heated
Aug 28, 2017 | Heating & Cooling
Tip
Tips for operating Air conditioning system on Toyota Hilux and someother...
To cool off your Toyota after it has been parked in the hot sun, drive with the windows open for a few minutes. This vents the hot air, allowing the air conditioning to cool the interior more quickly.
Make sure the air intake grilles in front of the windshield are not blocked (by leaves or snow, for example).
On humid, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
Keep the area under the front seats clear to allow air to circulate throughout the vehicle.
On cold days, set the fan speed to high for a minute to help clear the intake ducts of snow or moisture. This can reduce the amount of fogging on the windows.
When driving on dusty roads, close all windows. If dust thrown up b the vehicle is still drawn into the vehicle after closing the windows, it is recommended that the in intake be set to FRESH and the fan speed to any setting except "OFF".
If following another vehicle on a dusty road, or driving in windy and dusty conditions, it is recommended that the air intake be temporarily set to RECIRCULATE, which will close off the outside passage and prevent outside air and dust from entering the vehicle interior.
HEATING
For best results, set controls to;
Fan speed ---- Any setting except "OFF"
Temperature----Towards WARM (red zone)
Air intake ---- FRESH (outside air)
Air flow ---- FLOOR
Air conditioning ---- OFF
For quick heating, select recirculated air for a few minutes. To keep the windows from fogging, select fresh after the vehicle has been warmed.
Press the "A/C" button on for dehumidified heating.
Choose floor/windshield air flow to heat the voltage interior while defrosting or defogging the windshield.
AIR CONDITIONING
Fan speed --- Any setting except 'OFF"
Temperature --- Towards COLD (blue zone)
Air intake --- (outside air)
Air flow --- PANEL
Air conditioning --- ON
For quick cooling, move the air intake selector to recirculate for a few minutes.
VENTILATION
Air flow --- PANEL
DEFOGGING
The inside of the windshield
For best results, set controls to:
Temperature --- Towards WARM (red zone) to heat; COLD (blue zone) to cool
Air intake --- FRESH (outside air)
Air flow --- WINDSHIELD
The outside of the windshield
Air conditioning --- OFF
On humid days, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
DEFROSTING
To heat the vehicle interior while defrosting the windshield, choose floor/windshield air flow.
on Feb 14, 2011 | Toyota Pickup Cars & Trucks
AIR BLOWING LIKE IT'S ON FAN EVEN THOUGH IT IS ON COOL
close vent for outside air.....if not then probably lost its chaerge.
Oct 11, 2017 | Heating & Cooling
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Car blows warm air when idling
It sounds like your AC unit could be overheating or even damaged.
AC units have a sensor that will turn them off automatically to prevent damage from overheating. If there is an insufficient amount of air flow, the unit will heat up, and then eventually turn off.
When the car is moving, more air is forced over the unit, likely keeping it cool enough to run, however, when the car come to a stop, it loses that air flow, and quickly heats up. Thus, the AC would work while the vehicle is in motion, and overheat and stop when the car is stopped and idling.
However, the AC unit could be completely blown. The cold air while moving could be just a case of air being forced into the car. Think of a house fan, the fast the wind blows on you, the cooler it gets.... Thus, it could be an illusion that the AC is working when car is in motion, when it really isn't.
Hope this helps.
Jun 09, 2012 | 2004 Lincoln LS
No water collected
check to see if the fan is blowing across the condenser. there should be warm air blowing out the back. if there isn't, the fan may need to be replaced so the heat exchanger can cool down. may be running too hot. also check the condenser in the front to see if the air flow is blocked with dust. if so, change the filter if it has one. if there is cool air blowing, the compressor may not be turning on.
May 11, 2012 | Dehumidifiers
The air is not cool when idling, it blows warm. Also the setting 1 and 2 doesnt work, only 3 and for makes air blow.
Sounds like 2 different problems here. The ac gets warm when standing idle, is most likely the under hood fan not kicking on when ac is on. This may be a fuse issue or a relay. When ac is on, the fan should be on all the time. Relay maybe in an electrical box under the hood. Unplug the fan and test for power with a test light to see if the fan has power when ac is "on".
The inside fan not working on levels 1& 2 is likely the voltage ballast issue. this is an electrical block which controls voltage to change fan speeds. Usually found under the passenger side dash, right in the air flow comming from the fan and inside the air flow housing. Usually held in by 2 or 3 screws with a connector and 3-4 wires sticking out. this should be under $20 to buy and quite easy to change, if you can find it. Try behind glove box etc. Do not test the new one without it being in place, as it may burn out very quickly without the air flow to cool it.
Good luck
Apr 30, 2011 | 2002 Chevrolet Cavalier Coupe
Unit does not cool. Original unit was replaced because of defective compressor. Replacement unit worked in store but now does not cool and alternates blowing cool and warm air.
Is this a window unit? Sounds like the compressor may be cutting on and off. That would cause the alternating air temp you are feeling. Make sure the condenser fan is running. If it isn't running head pressure will build up on the compressor until it shuts down. Then the pressure will equalize and the compressor will kick on again. Also check your filters and the condenser coil to make sure it is clean. Let me know what you find.
Jul 08, 2010 | Frigidaire Heating & Cooling
The fan is constantly running and part of the laptop gets really hot
Check the vent where the fan should be blowing out hot/warm air for good flow. If you don't have any air flowing, you might find that the fan inlets are plugged with dust, or the fan blades are covered with dust/fuzz. Clean all the air passages, inlets and outlets to make sure the fan can flow enough air to cool the computer.
tom
Jan 18, 2010 | HP Pavilion dv7-1260us Notebook PC
Daikin FTXS24HVJU Logo
11 people viewed this question
Top Daikin Heating & Cooling Experts
gbob59
Fotis Papastamatiou
Are you a Daikin Heating and Cooling Expert? Answer questions, earn points and help others
