Question about Eureka 4700A Maxima Bagless Upright Vacuum
Motor loud Sucks up ok belt ok but sounds like a freight train when started, no smoke.
    Problem Solver:
  • 9 Answers
The beeter bar bearings are bad i just changed the beeter bar on a vacuum that fixed the loud noise check for play in the old beeter bar brush
Posted on Feb 09, 2015
Hoover vacuum started smoking
Sounds like the roller became stuck and the motor burnt the belt into. I worked on Hovers for years and that is the most common problem.
Apr 02, 2014 | Hoover U5750-900 WindTunnel Bagless...
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Dyson makes loud noise
Could be damage to Fan within motor or shaft on motor..Remove brush roll and run with nothing connected to motor ,if noise still appparent then sounds like one or the other if ok then check for damage to the brush roller.../Housing..good luck
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Was hoovering when my DC04 made a funny high pitched noise then a whirring noise, this was accompanied by a smell of burning and a puff of smoke! Almost sounds like it might be a clutch slipping, is this...
OK... the DC04 doesn't have a clutch. My best guess is that the belt that drives the brush roll has broken. The smell of burning and smoke puff were probably caused by the motor suddenly speeding up when freed of its burden of driving the brush roll. For illustrated guidance on checking (and if necessary changing) the belt, go to www.dysonmedic.com then scroll to the bottom of the page and click on "DC04 Belt Change Guide".
I hope this helps. If so, please remember to rate this response. If not, please post a reply and I'll try again. Good luck!
Feb 05, 2010 | Vacuums
Vacuum sounds like an airplane after 1 year of use.
the motor bearings are starting to fail most likely. You can diagnose the source of the noise by removing the brushroll and belt, could possibly be the brushroll bearings but if you still get the noise when the belt is off its the motor.
Jan 07, 2010 | Bissell 6594 PowerForce Bagless Upright...
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
SWEEPER STOPPED, WITH A LOUD HUMMING SOUND. THE
Do not turn on again. You have an obstruction in the fan . You will need to remove the motor from the lower housing, dismantle the fan cover and remove the obstruction, possibly replace the fan as well.
The lower housing plate can be removed revealing a set of clamps around the motor hosusing which will in tun release the motor from the base of the vac.
Sep 09, 2009 | Hoover U6630-900 WindTunnel Bagless...
Vax mach 5 burning smell and revving loud
The revving/burning is because the belt is burning off and the power head motor is running without load...
Flip the carpet power head upside down on the rug and look for visible screws and screwdriver release slots on the bottom plate of the head.
When you remove the burned belt determine the cause. Will the brush roll freely or is it jammed with hair and fiber?. Clean the burned rubber from the motor shaft before replacing the broken belt, available at a vac specialty shop.
Sep 04, 2009 | Vacuums
Eureka 5197 self propelled bagless upright
Did you check the brush roll when you changed the belt? The smell of rubber would inducate a belt slipping. So if the brush roll (part #61308-2)isn't turning, the belt would get hot and would be slipping. If the motor sounds real loud, then you could have a bad motor(part #60775-4).
Feb 14, 2008 | Eureka 5197AT Upright Vacuum
Eureka 4700A Maxima Bagless Upright Vacuum Logo
107 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
