Question about Technics SL-1210 Turntable
Sears Tape deck/Turn table skipping!
We just put a brand new cartridge on it and its skipping the first time we played records on it. Will a bunch of pennies on the needle mess up my records? could it be the tone arm isnt skating properly? if so, how do you fix that?
    Scholar:
  • 113 Answers
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Posted on Jul 22, 2009
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Every record skips in different places
You should look for an anti-skate control on the turntable and adjust that. It will be a question of trial and error with it as there is no fixed rules for these. The weight on the back of the arm should be set to the weight of your cartridge.
Dec 11, 2012 | Sony PS-LX300USB Turntable
Can I connect a tape deck *and* a turntable to the Sony STR-DE595?
If your turn table has a magnetic cartridge it will not work,Becuase the ner recievers are not equip with a phono preamp, They are equip to only use a crystal or ceramic cartridge in the turn table.
Sep 29, 2012 | Sony STR-DE595 5-Channel Amplifier
When I play a tape on a Sony TCW475 dual cassette tape recorder/player there is this loud clunking noise as it begins to play. How can I fix this? It is brand new.
If the clunking is in the deck itself and not in the speakers, it's actually probably normal.
This "clunking" is the unit electro-mechanically lifting the heads into place.
Mar 25, 2011 | Sony TCW475 Single Dual Cassette Deck
Need to find user manual. I have a problem in recording a tape. I put in deck1 --- cassette to be recorded in deck2 new cassette start play on deck1 ... turn on record and play in deck2 as...
for a start your title says "Problem with the Technics RS-TR272 Single Cassette Deck"
So is it a single or double?
i'm assuming it's a double,right only one of the decks records so put the blank tape into it make sure the tabs on the top of the tape haven't been broke or you'll need to cover the holes with the labels you get with the tape.
put the tape with the music on it, in the other deck rewind them both then press "sync rec" & they should both set off.
Mar 01, 2011 | Technics RS-TR272 Single Cassette Deck
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
How do I record from one tape deck to the other?
Put your "blank" in the deck with the record button, normally red button and press rec/play and pause at the same time, put your "origional" in the other deck and press play and pause at the same time, then un-pause both at the same time. Make sure that the hifi is set to tape as if you record tape to tape when listening to radio foe example, you will get a strange "mix tape" of your origional and the radio.
Jun 05, 2009 | Audio Players & Recorders
Audio tape cassettes,old pre-recorded and home recorded play too slowly and drag. All brands. Tape deck plays new tapes fine.
A good cleaning to the rollers and tape head with a qtip and a small amount of rubbing alcohol should do the trick
Feb 26, 2009 | ION Audio TAPE2PC Single Cassette Deck
Will not dub another tape
This site is useless. It tells you nothing.
Why does it exist?????
Jan 19, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Cassette tapes
try firmly banging the cassette onto a table top(with reels flat) a few times, then ff right through and rew a couple of times. this will layer the tape more evenly and hopefully allow the mechanism to play it. the takeup reel or autostop mechanism may be failing if the deck does not have enough torque to carry the tape and may require belts replaced or dried grease removed in the transport.
Dec 07, 2007 | Tascam 202MKII Single Dual Cassette Deck
Technics SL-1210 Turntable Logo
341 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
