Question about Vehicle Parts & Accessories
Replace throttlebody on 2009 equinox ltz 3.4 v6 eng.
How to replace.
    Master:
  • 467 Answers
Dic reset for chevy equinox tire presure
If the light will not reset when tires are properly inflated then one of the sensors inside the tire is defective, they are battery powered and last about 3-5 years. A GM dealer can scan the system and ID the problem more accurately. In most cases it is just the sensor.
Oct 07, 2016 | 2010 Chevrolet Chevrolet Equinox LTZ
Hood switch location 2009 chevy equinox
The factory hood ajar switch is integrated into the factory hood latch.
It is a 3 wire connector with Pink/Black (A), Purple (B), and Black (C) wires in it.
Wires A and B are signal wires from the BCM, Wire C is the ground.
Jul 02, 2016 | 2009 Chevrolet Equinox
I need the easiest possible directions to replace the coolant temperature sensor in my 1999 Chevy Lumina ltz 3.8 v6 car please.
The coolant sensor temperature is usually found just beneath the cylinder head, on the engine block.
You just disconnect the 1-2 wires and then undo it with a wrench.
The sensor will look like one of these:
1999 Chevy Lumina ltz 3 8 v6 coolant temperature sensor Google Search
Just be aware .. you may have TWO such sensors on your vehicle.
One sensor (usually with 3-4 electrical pins) is near the thermostat and works in conjunction with other sensors to regulate fuel/air according to engine temperature.
The other type of sensor is in the block near the cylinder head. It sends a signal to the temperature gauge on your dashboard ONLY. If your temp gauge constantly reads too hot or too cold .. this one is the culprit.25939754-r0ibht2u2t2rhetbyfvb2pry-5-0.jpg
If it's a running fault .. speed .. rough running .. fuel. It may look like this:
Nov 03, 2015 | Cars & Trucks
I have a 2009 chevy traverse the ac light is flashing 3 times and then blowing hot air
It's trying to tell you there is a problem an you need to have it checked, DTC - diagnostic trouble code stored in The HVAC control module !
Jan 24, 2015 | 2009 Chevrolet Chevrolet Traverse LTZ
Fuel trim system rich bank 1
2009 Chev Impala LTZ 3.9 v6
code p0172 bank 1 rich eng surging
Jan 11, 2014 | 2006 Chevrolet Aveo
2009 Chevrolet impala ltz 3900 flex surge under
Fuel filter, air filter, check for vacuum leaks.
Assuming the engine light is NOT turned on, if it is on, it needs to be diagnosed.
Oct 28, 2013 | Chevrolet Vehicle Parts & Accessories
2009 chevrolet ltz keeps blowing left taillight fuse. When fuse is replaced it will last for several days before blowing again. Any advice?
Check bulbs for corroded plugs and clean them with some contact cleaner and sandpaper and reinstall with a bot of dielectric grease
Sep 22, 2013 | 2009 Chevrolet Chevrolet Suburban 1500 LTZ
When i fill my tank with gas on my 2009 malib ltz v6 3.6 it takes long to start but after it start that never happens again untill i fill the tank again
try changing your fuel filter or fuel pump i would start with the fuel filter first and do process elimination
Mar 15, 2013 | 2009 Chevrolet Malibu LTZ
Vehicle Parts & Accessories Logo
23 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
