Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Loss of audio and video
Picture and sound would flicker on and off there is nothing at all (except for chanel and volume display) on all inputs.
Pioneer SD-P5053 (or P5O53...can't tell if its a letter or number 0 or O)
Product listed below is incorrect...only chose it to continue. Says my product invalid.
  • Pioneer Master
  • 5,138 Answers
Take to repair shop.
Posted on Feb 08, 2008
Harman kardon Avr 254 fix. No video trying to find out which time delay fuses to bypass. Does anyone have a picture. Lost all video and front display locked up except for volume and radio
I never recommend running video through any receiver. It's best to connect your playback or broadcast devices directly to your monitor.
Jan 01, 2015 | Audio Players & Recorders
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
The center chanel port does not produce sound and sparks when i plug the wires into the jack. all other chanels work except the center.
It seems that the center channel has DC voltage at the output terminals, center channel amplifier is blown and you need to bring the receiver into a repair shop. You can use a voltmeter to check DC at speaker terminals, all channels should have 0 volts when no input signal applied (or volume control set to minimum).
Do not connect your speaker you can damage it.
Jan 09, 2011 | Audio Players & Recorders
Radio has no sound ,chanels display and volume
your factory amplifier is more then likely to be at fault
Mar 19, 2010 | 2005 Jaguar X-Type
Don't have manuel and don't know how to Set up Hitachi VCR
Such a simple job. First check if the cables are connecred properly
1. Audio OUT from VCR to AUDIO IN of TV.
2. Video OUT from VCR to VIDEO IN of TV
Then switch the TV ON. Select 'Video' on the TV/Video
selection button on the TV's remote control.
Your TV screen will show a display like 'Video' or 'AV'
Play a cassette and you should be able to see the picture...
Happy Viewing.
Apr 01, 2009 | Televison & Video
No Sound Issues
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
Oct 13, 2008 | Sony KV-32FS13 TV
Volume on surround sound speakers not working. Sound coming out of speakers but volume when turned to maximum is very low. Please help.
Most receivers you can adjust the different chanel levels. If you refer to the manual on adjusting chanel volumes in surround sound mode.
May 26, 2008 | Audio Players & Recorders
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
57 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
