Question about Hannspree Computers & Internet
Only my left speaker is emitting sound. Drivers were updated already through device manager
SOURCE: No sound from center and rear speakers
i had same problem and this probably isnt the same as yours but all i did was click on the speaker symbol on the taskbar and under speaker configuration set it to 6 for the sound card i think the default setting must be 2 because thats what it was set at hope this helps someone cos i was gettin so annoyed at only having 2 speakers and woofer working
Posted on Dec 09, 2007
SOURCE: 5.1 surround not working
I uninstalled the previous audio software that the computer had. (Realtek HD audio) and turned off the onboard sound card in the BIOS settings. Then I went back and uninstalled all the new audio software and reinstalled it with all antivirus programs turned off. The main trick was to make sure that the matrix is turned off. If it is on it will play sound from all the speakers at once as if it were mono. Turning it off after changing the BIOS and uninstalling the old software and reinstalling the new allowed it to work properly. I hope this helps.
Posted on Sep 11, 2008
jell587
  • 447 Answers
SOURCE: No Sound on Emachine T5048
Download the Realtek HD driver from here, re-install. Should fix the issue.
Posted on Feb 20, 2009
SOURCE: Compaq Presario C700 No Audio Issue
better buy sony computer.......compaq computer no good!
Posted on Apr 06, 2009
  • 1702 Answers
SOURCE: I can't get my speakers to work. I have a
Hi, Make sure the speakers are plugged in to the green plug on the card. Also make sure card is properly in the right slot. Good luck.
Posted on Sep 22, 2011
Audio device not installed
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Feb 03, 2013 | Microsoft Windows 7 Ultimate 32bit
Audio device
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps
Jan 16, 2013 | HP Compaq 6730s Notebook
How can i restore the sound .it gone off after using haedphones
Which operating system ?
You should not need to do a system restore to get sound after using headphones.
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers. Click start control panel sounds and audio volume advanced speakers make sure you have selected the (appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
If his does not fix the problem Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume. You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
dust causes static to build up in a computer http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: motherboard name audio driver you might have to try a few times to get it right for windows 7 Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps
Dec 12, 2012 | Sony Vaio VGN TX2XP/L Laptop Universal AC...
Dg31pr sound driver headphone and speaker on each other in wndows 7
the headphone should need a driver
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
hope this helps you
Sep 20, 2011 | Intel DG31PR Motherboard
No audio
Is this the 1st time you used it?
Check if the Soundcard Driver is already installed
Right Click "My Computer or Computer" in Windows taskbar Select Properties Select Device Manager Look for your SoundCard Double Click, check if the device is working properly
If the soundcard driver is already installed, check your speaker connections & your speaker
Apr 05, 2011 | Computers & Internet
No audio even i already installed the audio driver
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Feb 02, 2011 | Asrock P4VT8+ P4 PT800 Prescott Ready...
Sound comes out of all speakers but the sound from the left speaker plays through the left, right, and sub. instead of just the left speaker. so i have guitars coming out of the sub and bass coming out of...
you might have to select stereo speakers in the drop down list
also
hope this helps
dont forget to vote
Jan 31, 2011 | Kinyo PS-107 Computer Speakers
I have a problem of my sound on my pc would you please help me..i dont know how i fix ..strat whn i fix my yahoo..then my sound is already gone..
also
hope this helps
Jan 31, 2011 | Computers & Internet
My computer doesn't register this device at all. The output is working to my speakers and the power light is on but that's all. Someone in my office suggested that I need to update my USB drivers?
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
also
hope this helps
Jan 27, 2011 | Behringer (UCA202) Sound Card
No sound coming from the left speaker.
control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver or select system devices from the device manager scroll to speaker right click to update driver,disable,scan for hardware changes or select properties to troubleshoot,then select driver to uninstall,rollback,uninstall then reinstall
hope this helps
Nov 24, 2010 | Altec Lansing ATP 3W Computer Speakers
Computers & Internet Logo
14 people viewed this question
Top Hannspree Computers & Internet Experts
justwinwin
Computer Links
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
