Question about Samsung WF317AAG Front Load Washer / Dryer
SCHEME TO MOTHER BOARD
NOT DRAINING POWER NOT GETTING TO THE PUMP PUMP WORKS
Maytag jetclean quiet plus fills but wont wash or drain.
The mother board is going out, or the drain pump is failing. Try un plugging it...... by which i mean turning the power off to the unit and doing a soft reset. See if it recycles into the normal mode and works.
Mar 06, 2015 | Maytag Dishwashers
Hoover oph714d
Hi! If it won't drain out then check the drain hose. Maybe it's blocked or kinked. Then check the pump impeller, there may be blocking impeller. Anyway, here are washing machine manuals where you may find solution of your problem Washing machine service manual repair scheme download pdf free
Mar 19, 2014 | Washing Machines
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Washing Machine
Check out the fuses on the main controller board if they are fitted. If you need a new motherborad you can get one from Fisher & Paykel in Australia at http://www.fisherpaykel.com.au/customercare/contactus/
Sep 08, 2012 | Fisher and Paykel Washing Machines
The cleaning button flashes, not able to reset
Please remove the power plug and keep aside for a while as the main control panel buttons are pressed to remove any residual voltage on the main board / processor.
If this wont reset then check the input sections, the door switches, the drain filters, the drain pump. Remove, clean and reset.
If not there are faults in the mother board.
Sep 01, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My cmos battery goes discharged in 4 -5 days . after replacing the battery it works for again 4-5 days and again goes bad.. my motherboard is inteldg41ty
Possible that the mother board has a higer current drain on the back up circuit . You can remove the button cell and check on the board/connections around this section. If there is dirt or moisture wash the board after removing power- allowing time for voltage to drop - use petrol and a tooth brush to clean this section. if the fault does not clear then the mother board has to be checked.
Jul 21, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
OE Code LG washer - cleaned filter, checked pump still not working. Checked pump for power when should be draining and found no power to it. Pump not being told to drain. Help?
It is a long drain error. The washer is not fully drained after 10 minutes of draining. Remove the cabinet cover and check the following:
  1. Connector The connector may disconnected or disassembled. Reassemble or repair if necessary.
  2. Drain pump coil
    Check pump coil resistance between the terminals using an ohmmeter. Resistance should be between 10-20 ohms. If the resistance is too high or too low, replace the drain pump.
  3. Voltage Check the voltage between the connector in step 1 during spin. The voltage should be 120Vac, else replace the main board assembly
Main board replacement:
  1. Disconnect the power connector and sensor switch assembly.
  2. Remove the main board protective cover.
  3. Disconnect the connectors.
  4. Remove the screw on the back of the main board.
  5. Slide the main board to the right then pull it up.
  6. Replace the main board in reverse order above.
Nov 10, 2009 | LG WM-2277HW Front Load Washer
I have AMD Athlon 64 Processor 3700+ not reading at 2.40 GHz
Try going to Control Panel -> Power Options and changing the Power Scheme to Always On.
Mar 26, 2009 | Computers & Internet
Samsung WF317AAG Front Load Washer / Dryer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
