Question about Seiki 32" LED HDTV SE322FS - CAM CONSUMER PRODUCTS, INC
Picture stopped working black screen
Sound is fine but there is no picture, was working fine, but turned to black screen, and wont show picture.
Screen black
Call apple and explain this, cause it sounds like a factory glitch and there's no fixing it except through Apple
Jan 02, 2014 | Apple iPhone Smartphone
Black Screen - Can not get menu to show to adjust brightness.
You need to replace the inverter board thats what preventing the backlights from lighting up so you can see the picture. You can get the inverter board from www.tvrepairworld.com
Jan 10, 2013 | Dynex DX-32L151A11 32-inch Flat Panel LCD...
Rca L42phd37yx8 42' led tv blackscreen with sound wont show anything
Show a torch light on the screen (not too close) when the TV and program is running. If you can see the picture, the backlights have gone off. Anyhow, the TV needs attention by a qualified service technician.
Jul 13, 2012 | RCA Televison & Video
Black screen on canon a 550
Sounds like you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on or off to save batteries. You would then use the optical viewfinder, just like you've been doing. To turn the screen back on, press the button once more.
Oct 11, 2009 | Canon PowerShot A550 Digital Camera
My mitsubishi vs-8087's screen wont show picture at all
this will need some testing to find out what component has failed and stopped the video processing
Dec 10, 2008 | Mitsubishi VS-8087 80" Rear Projection...
Sony KV34HS420
It sounds like you have tried changing imputs " usually the issue". The next step is to see if it is still under warranty and get an estimate of how much it will cost to fix. Invest in a good surge protector.
Mar 09, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Canon Powershot sd30 Black screen
Then it sounds like there may be an error with your CCD (what comverts the light going into your camera into a digital picture, like digital film). even if your warranty is expired canon may still repair this for free. Contact canon at 1-800-OK-CANON and explain to them the problem and that you think the CCD may be defective.
Jan 31, 2008 | Canon PowerShot SD30 Digital Camera
Seiki 32" LED HDTV SE322FS - CAM CONSUMER PRODUCTS, INC Logo
42 people viewed this question
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
