Question about Camping, Backpacking & Hiking
Freezing food can cooked yams be frozen?
4 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: freezing problem
HI thanks for your question. try turning the thermostat to a lower, number. and clean all the coils at the back by the compressor. it might be all you have to do/ thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 12, 2008
  • 5 Answers
SOURCE: Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
Posted on May 29, 2009
machinetech7
  • 1344 Answers
SOURCE: whirlpool side by side , the refrig temp is at 49, the freezer will keep food frozen, but will not freeze , not even ice cream
Not sure exactly what the situation is I'm going to give you a detailed overview on how the system works that way you'll be able to isolate the problem. Your machine is a single compressor unit, meaning that even though there are two seperate sides, the freezer and the refridgerator, they do not operate independantly. The sealed system, which is what cools the machine, has two parts, a high side and a low side. The high side is located under the machine and consist of a condensor, for which freon is pressurized back into a liquid and passed throug the compresoor to be released as a gas into the evaperator, the low side. This is where the freon is at a cold state. Ok, now that you have the bare basics of a sealed system, we move forward. The Evaporator is located in the freezer side, behind the freezer wall. As freon goes through the evaporator, a fan, called the evaporator fan, is located above it and circulates air throughout the freezer compartment. Also, an airway connects the freezer to the refridgerator, usually top right of freezer, or top left refridgerator on side by sides and through the freezer floor on top mount models. This means the freezer cools the refridgerator side. ****First check point**** Is the fan running in the freezer? This would cause the freezer not to cool as well but also a rise in the refrigeration side would be noticed. As freon goes throught the evaporator, which is made of aluminum, the temperature levels are well below the freezing point, so frost and ice will form on the coils. Over time, this kind of build up would form a blockage, not letting air be drawn from the bottom of the coils by the fan to circulate the cold air. To prevent this from happening the a defrost heater is installed to thaw the ice away and comes on every 6-8 hours. This is initiated by the defrost timer, or in some machines an adaptive defrost control. The heater will be located at the bottom of the evaporator because hot air rises, getting maximum effect. A third part to the defrost system, the first two being the timer and heater, is a bi-metal,or terminating thermost. Its called this because when the thermostat is cold, the metal inside it constricts making a pathway for electricity to flow through to the defrost heaters so it can get hot, and as the heat rises and the ice melts away, the terminating thermostat will warm up, and the metal will expand causing the path of electricity to be broken, turing the heaters off. This is to prevent any high temperature situation from happening, like melting plastic or even a fire. If any of these parts fail, the machine will nit defrost. ***Checkpoint two***** Do you see any ice build up on the freezer wall. This ice will be completely across the back wall. Most signs of defrost problems are noticed first by a rise in temperature on the refrigerator side first. The above can be assessed with a quick look and listen. If no frost is present and the fan is running you can rule out the above. ****Please not that ice build up on just a small section, for example, upper left or right corner only is not a defrost situation but a sealed system issue, caused from low freon or a restriction in the lines and a EPA certified technician should be called.****** The last thing you should check you'll need to pull the machine away from the wall and remove the lower panel to gain access to the compressor area. What you are checking here is to see if the condensor fan motor is running and that the coils are somewhat clean enough for air to flow across them. The fan draws air from across the compressor and through the coils helping to keep the compressor temperature down and also to evaporate the water that is drain when the machine goes into defrost. Rule of thumb is if the compressor is on the fan should be. If the fan isn't runnning the heat from the compressor will be transferred to the machine and notice first on the freezer more so than the refrigerator. ****checkpoint three**** IS the condensor fan running? Are the coils clean, and can you feel the air from the fan with your hand placed on the opposite side of the coils?
The refrigerator side is usually where your defrost timer, discussed earlier is located. Also on this side is where your temperature control, or controls , are located, These controls are what are called thermostats, and have a direct line to the compressor. This means when the temperature has reached the desired setting the thermostat will kill power to the compressor in the same manner the terminating thermostat does with the defrost heater. Some models have a temperature control thermostat for the freezer and the refrigeratot, but some only for the refrigerator. The most noticeable sign of a thermostat being bad is the food in the refrigerator side will freeze, usually on any setting or the machine won't come on at all, including the fans. Problems are usually noticed on the refrigeratot side first. The last thing to discuss is The freezer and the refrigerator both are rising in temperature, but the fans are running, etc. Normally in cases like this a humming sound followed by click is heard or sometimes just the click. The humming sound is the compressor trying to start but failing and the click is the relay breaking contact. On newer machines, especially ones that fall under the whirlpool umbrella, the compressor relay, also called the start device has failed and needs to be replaced, but also the compressor itself could be bad. Well, thats the basics. I know it's long winded but I wanted to put something that you could print out and use as reference. Good luck.
Posted on May 25, 2012
I have little tomatoes almost golfball size how do I freeze them as I am a novice of how to save produce I grew!thks
It is possible to quickly freeze raw tomatoes without blanching them first. They may be frozen without their skins or frozen whole with their skins. Frozen tomatoes are best used in cooked foods such as soups, sauces and stews as they become mushy when they're thawed
Jun 12, 2017 | Computers & Internet
Had a joint left over from party can i freeze it
Anything can be preserved by freezing but not everything is suitable for freezing because either the consistency of the food is destroyed or drastically changed by the freezing/thawing process or because the thawed food will not tolerate the thorough reheating that will be required to make it safe to eat.
Cooked, chilled foods that are perfectly fresh can be frozen and eaten after thawing with a fair degree of safety and such things as strawberries can be frozen even though they become a sort pulp after thawing.
Personally, I don't eat much from the freezer that hasn't been thoroughly heated/cooked right through...
Apr 10, 2016 | Grilling
The label on my frozen turkey says it is good till March of 2016 does this mean even if its thawed it will still be good till that date?
Hi Ronnie:
- If it has been sitting unfrozen in your fridge for more than 2 days I'd personally not be eating it.
- Likewise, if you cook it, it should be eaten right away.
- Re-freezing uncooked is not considered safe food protocol.
- Freezing cooked in serving size portions and only thawing when you're going to heat and eat is usually safe.
Hope this helps.
Nov 14, 2015 | Toys
Can I freeze hors d' oeuvres with cream cheese wrapped in flour tortillas?
I would say "yes".
Things that don't freeze well, according to Deborah Taylor-Hough, author of Frozen Assets: Lite & Easy (Champion Press, 2001), are egg-, milk- or cream-based sauces, instant rice, raw salad ingredients, dishes with dried toppings (store the toppings separately), mayonnaise unless it's mixed in and used as part of a sauce, cottage cheese, hard-cooked eggs and fried foods, which will lose their crispness.
The key is how you store and freeze them...go to the attached link:
Frozen assets Have appetizers waiting for unexpected guests
Mar 01, 2015 | Cooking
Can a fully cooked Cure 81 ham that has frozen then thawed and warmed-up be refrozen?
Yes It can be, the textures will keep on changing the more you do it.
It is preferable that you divide any cooked or uncooked food to the portions that can be consumed in one time, before freezing, this will maintain a better taste and texture.
Feb 03, 2015 | Refrigerators
What are the different types of dog food?
Different types of dog foods are:
1. Wet foods that have high content of moisture in it.
2. Dry foods that contains low amount of moisture.
3. Semi-moist foods which have soft pellets with a chewy texture.
4. Frozen foods that are available frozen or freeze-dried formats.
Jul 18, 2012 | Dogs
Is it safe to refreeze meat, such as venison steak after it has completely thawed?
Refreezing
Once food is thawed in the refrigerator, it is safe to refreeze it without cooking, although there may be a loss of quality due to the moisture lost through thawing. After cooking raw foods which were previously frozen, it is safe to freeze the cooked foods. If previously cooked foods are thawed in the refrigerator, you may refreeze the unused portion. Freeze leftovers within 3-4 days. Do not refreeze any foods left outside the refrigerator longer than 2 hours; 1 hour in temperatures above 90 °F.
Sep 04, 2011 | Refrigerators
Frezeer was unpluged by accident. All mear thawed out. Is it ok to refrzeethe meat and eat it later.
Is it safe to refreeze food that has thawed completely?
although there may be a loss of quality due to the moisture lost through defrosting. After cooking raw foods which were previously frozen, it is safe to freeze the cooked foods. And if previously cooked foods are thawed in the refrigerator, you may refreeze the unused portion.
If you purchase previously frozen meat, poultry or fish at a retail store, you can refreeze if it has been handled properly.
(Source: Freezing and Food Safety)
Charlie
Feb 10, 2011 | Refrigerators
We have recently purchased a Coopers halogen oven. I cooked a frozen fruit pie in it and the pastry looked beautiful, but when it was cut open the middle was cold and the pastry under the fruit not cooked....
Frozen food should be defrosted before cooking in halogen ovens.
Halogen ovens use only radiant heat and will not cook the centre of frozen food.
Jan 21, 2010 | Ovens
I can not change temperature to more than 41f. Lower temperatures are OK
Temperature is perhaps the most critical means of control in the prevention of foodborne illness. Harmful (disease-causing) microorganisms grow within a temperature range of 41 F to 140 F (referred to as the "Temperature Danger Zone"). Many foods, especially raw animal products, naturally contain harmful microorganisms. Keeping foods out of the Temperature Danger Zone prevents disease-causing microorganisms from growing in foods. Proper cooking and reheating of food is important because heat destroys disease-causing microorganisms that may be present. Ensuring proper heating and storage temperatures is essential for assuring safe food in retail operations. Temperature guidelines differ depending on the type of food and method of heating method.
Freezing
Most pathogenic microorganisms will not grow below 41 F, or their growth will be very slow. However, many spoilage microorganisms (which cause foods to taste and smell bad) can grow at temperatures well below 41 F. Most foods that are frozen in food retail are done to improve quality and increase the shelf- life of the product. Most foods will freeze at about 28-30 F. To ensure safe freezer temperatures, be sure that your freezer is maintained at least 28-30 F or below (foods should be frozen solid). Ideally, foods should be frozen at 0 F or below to maintain quality.
It seems that your Refrigrator's higgest point is set to 41 F
Jun 19, 2009 | Refrigerators
Camping, Backpacking & Hiking Logo
63 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
