Question about Frigidaire GLEQ2152ES Electric Dryer
LEQ2152ES 2005 dryer shuts off when start us pushed
Ran dryer for about 10 min, to warm clothes for folding, place new load of wet clothing inside and pressed start. stopped immediatly and start button flashes no error code displayed. had timer replaced 2 months ago has been working fine til today
  • 547 Answers
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Posted on Jun 19, 2009
  • 1 more comment
  • albert getty
    albert getty Jun 19, 2009
  • albert getty
  • albert getty
LG Model DLE1501W - I set the dryer for appropriate cycle. It shuts off after 10-15 mins or so. clothes are still wet.
The moisture sensors seem to be the issue. The two metal bars on the lint filter housing. Try cleaning with alcohol and stop using dryer sheets.
Dec 14, 2016 | LG Dryers
Clothes still wet after spin
it is normal for clothes to be a bit wet after spin.approximately about 80 percent of your clothes will be dry after spin. you may hang your clothes to completely dry or place it inside a drier machine
Sep 03, 2015 | Maytag Bravos 3.8 Cu. Ft. Washer
The dryer does not pass 6 min mark and does not shut off. How would I test a humidity sensor? Thank you for help.
A dryer moisture sensor can stop working without notice, until you notice your clothes being over dried or still wet at the end of the cycle. It is a good practice to test the dryer moisture sensor periodically. There are two types of moisture-detecting sensors for dryers. Once you understand how they work you will see how to test each one.
1. Sensor BarThese sensors contain digits that protrude outwardly. They work on an electrical current and the moisture from the clothing.
The first step to test is to place completely dry clothes in the dryer and turn on the dryer; it should run for a few moments and then shut down right away.
Secondly, place damp clothes into the dryer, turn on the dryer and watch the timer. As the clothes begin to dry the timer will move and shut off.
2. ThermostatThe timer is regulated by the thermostat. The thermostat rests in a closed position. To test this type of moisture sensor, place damp clothes in the dryer. Watch the timer; as the clothes begin to dry, the thermostat should open and the timer will move forward ,eventually shutting off.
Sep 08, 2013 | Dryers
I have a bran new Admiral dyer that won't work
The dryer may have been wired incorrectly, e.g., 115v rather than 230v.
May 23, 2017 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Unit will start and then shut off after 5 or 10 min
If this dryer has moisture sensing strips inside the drum I would clean them good with windex. As wet clothes rub against them the dampness tells the control to continue. If buildup from dryer sheets cause a barrier then the control will think them clothes is dry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 09, 2012 | Maytag Dryers
Clothes get warm but stay wet and do not fully
You need to check the venting. Take the vent hose off the back of the dryer and try drying a load with it off and see if it will fully dry. If so, clean the vent hose.
Nov 16, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer
hI YOU MIGHT JUST HAVE A VENTING PROBLEM iF YOU REPLACED THE THERMAL FUSE & IT WENT AGAIN tHE VENTING SHOULD BE LOOKED AT tHANKS FOR THE QUESTION tHE APPLIANCE DOC
Aug 30, 2008 | Maytag PYE2300AY Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
213 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
