Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Need to find the red reset button on the motor
Red reset button on motor?
Red reser button pops out after a few seconds, The brush is clear of threads.
Remove the belt from the motor to brush and then try. If the reset pops then the motor unit is faulty. If it doesn't pop off then the brush assembly is jambed or hard to turn, sometimes caused by threads in the roller endcaps
May 28, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Reset switch location
the reset button is in the on switch what you need to do is unplug from wall socket then press the on button down hard to reset.
Aug 14, 2013 | Dyson Vacuums
Model DC24. The brushbar does not revolve
the motors are very weak in the head, red reset button as the side hold down for 20 seconds to reset motor.
Jan 15, 2013 | Vacuums
Dyson animal dc07 does it have a reset button?
The reset button is incorporated into the on/off switch for the brushroller which is the grey button next to the red power button. Try hitting that button separately.
Sep 18, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a riccar vibrance red vacuum, just purchased with in 6 months and the roller brush wont go on and the reset button doesn't seem to push in or work I now live in Hankinson, ND 58041...there is a...
The reset button only pops out if the vacuum motor overheats. It does not affect the brush roll. If the motor is running the problem is most likely a broken or stretched belt.
Jul 26, 2011 | Riccar 8955 Upright Vacuum
I partially sucked up a rubber toy but was able to pull it back out and now the beater bar will not turn. Is there a reset button?
Apr 04, 2011 | Dyson DC25 All Floors Bagless Upright...
The motorized wand attachment keeps shutting down after 10 to 15 seconds after pushing the red reset button. I've thoroughly cleaned dirt/debris from around motor. Do I need a new reset switch? Thanks,...
either the reset is bad or the motor is drawing too many amps and tripping the reset. Do you have an amp meter? Check the amps being pulled by the wand attatchment against the load recommended by the manufature, this is usually located on a plate somewhere either on the wand or the canister.
Nov 24, 2010 | Rainbow E series Canister Wet/Dry Vacuum
The red button at the side of the roller brush to reset it on my dc24 rollerball doesn't seem to do anthing. What am I doing wrong the diagram shows that you push the button forward but I can hardly get my...
you need to use something small to push the red pin right in, make sure there is nothing blocked in the roller and this should reset the motor. The roller needs to be switched on next to the power button is well.
Oct 04, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Reset Button on my Dyson DC 25 Animal
What do you want to reset? Do you mean the motor has stopped working? There is no "reset button". The motor has an automatic cut-out, which will operate if the motor gets too hot and will reset itself when it cools. If the motor will not work when it's cool, then you have an electrical problem which will probably need professional attention.
Apr 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Roller motor on a DC17 dyson wont turn on
there is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor. try it
Feb 02, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
62 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
