Question about Hypertech Power Programmer Hypertech 32004 Power Programmer
HYPERTECH MAX ENERGY CODE 6F
IT SHOW AN ERROR CODE 6F HOW DO I GET PASS IT?
Need diagram 2005 dodge magnum v6 3.5 serpentine belt
There should be a picture in the owners manual. If you don't have one, you can Google the owners manual.
Dec 20, 2014 | Hypertech 2005 Dodge Magnum - SXT, 3.5 V6...
Where is iat sensor located
Usually the IAT is located in the air tube just before the throttle.
Small piece on the inside with a large connector on the outside.
Aug 14, 2014 | 2007 Jeep Commander - 3.7L V6 - Max Energy...
Why wont my hpertech 52500 after updated work for my truck
Howdie Best Bet IS Talk To Your Dealer On that Cause it Will cost YA Less then Me Cause they Got the Spec,s On it thks
Jul 30, 2014 | Hypertech 52500: Max Energy Power...
VIN numbers are often difficult to read and numbers get transposed. A capital "o" looks like a zero, etc. And transposition has happened at the DMV when title changes etc. My best advice is to look at the VIN as posted on the door frame sticker. If it's not there, you vehicle may be less than not-stolen. In that case look to dash, drivers side, base of windshield for riveted plate. CAREFULLY copy the VIN as stamped. Pay particular attention to O vs zero. Zero will usually look like a capital O with slash through it. Another misread is between numbers 3 and 8. When front half of 8 gets worn it looks like a three.
Mar 21, 2014 | Vehicle Parts & Accessories
Tuner will not go past system starting message
I think you're in the wrong forum, this sounds automotive to me and you're in outdoor power equipment
Nov 12, 2013 | Hypertech 52500: Max Energy Power...
Obd code C0502 on 97 chevy k1500
CO502 is a Vehicle Speed Sensor Code. I'm working on trying to resolve an issue with my own right now. I know I had some wiring issues a while back with the VSS and thought I had it all resolved. I didn't know that I still had an issue until I was installing my Hypertech Max Energy Power Programmer today when it gave me this code.
Sep 16, 2013 | 1998 Chevrolet K1500
How do i bypass the governer?
you have to get a programmer such as a hypertech max energy product. and you have to get one specific to the model of your car. there are many different brands but that should get you in the right direction. http://www.hypertech.com/products-results.aspx. remember the govener is set to the speed rating of your tires.
Jan 10, 2011 | 1994 Buick Roadmaster
How do I change the cooling fans to kick on sooner than they do? I live in the desert and its very hot! I put in a new thermostat which is better suited for my climate...but how do I get the fans to kick...
The only fix I have found besides adding a switch to the common terminal of the fan relay, and a ground, is to pick up the following ECU programmer from Corvette Central:
Click Here
Hypertech's Max Energy Programmer allows you to set engine cooling fan on/off settings, set top-speed limiter, engine RPM "Rev" limiter and even transmission shift points and firmness. Hypertech's Corvette Max Energy Programmers also allow you to return to stock settings or change settings anytime. Have you changed your tire and wheel size or differential, if so, and then you can make your speedometer corrections by using Hypertech's Max Energy Programmer.
It costs around $400 bucks, so definitely not a cheap fix, but it is a better fix.
Jul 17, 2010 | 2004 Chevrolet Corvette
I cannot update my Hypertech tuner on the internet max energy power programer part No. 32000
I cannot update my Hypertech engine tuner on the internet MAX ENERGY POWER PROGRAMER # 32000
Feb 08, 2010 | Hypertech Cycling
Hypertech Power Programmer Hypertech 32004 Power Programmer Logo
176 people viewed this question
Top Hypertech Power Programmer Computers & Internet Experts
David Payne
David Payne
Are you a Hypertech Power Programmer Computer and Internet Expert? Answer questions, earn points and help others
