Question about Grohe Home
Grohe rapido e valve repair
Rapido e valve
I have grohe 1000 shower and there is a constant water dripping from the head. What could be the problem
The water shut-off valve is leaking, thus not completely shutting off the water supply to the unit. Need to be repaired/replaced.
Mar 14, 2016 | Grohe Aquatower 1000 Shower System 27 016...
I have a wireless Grohe shower that keeps dripping hot water constantly
Your mixing valve(faucet) has a bad valve and is allowing the hot water to bypass and leak thru shower. You should replace the bad mixing valve or the faucet to repair and stop the leak.
May 10, 2011 | Grohe Home
I Have 25 year old Grohe two handle shower-only faucet, with very low flow from both valves. What could cause this? What parts might I need? Any tips on repair procedure? Many thanks!
Have you tried simply cleaning out the aerator?
Unscrew the aerator from the bottom of the faucet and clean out all of the debris on the screen and inside the fitting, then replace.
Sep 04, 2010 | Grohe Home
How to connect plastic pipe
hello Bill, the other end is attached to the valve pneumatic unit.
Look at this guide that might help you. though it is not the exact model, principle is the same.
Have fun
Avi
Grohe GD2 flush system concealed cistern repair fix and disassembly...
Jan 24, 2010 | Grohe 40367000 Chrome Accessories Single...
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
I have a grohe shower head which constantly drips. what do i need to replace to stop it?
the problem is in the shower valve not the head,....you should get all info on what the valve is and call someone who knows how to do these repairs,..don't do it your self if your not familiar with these types of things,..you could make a big mess,.......shouldn't cost much for an experienced person to take care of this,........good luck, cracklin joe
Jan 07, 2010 | Grohe Plumbing
Push button not operating fully/correctly. cistern flushes sometimes, but not always and is only two years old. It's a Grohe concealed cistern.
hey,
Check your button/s panel, check that the hoses are connected firmly.
Disconnect the hose and blow air through it, does it work now?
If it works ok, you need a new buttons panel. (or fix it).
If problem remains, you need to disassemble the pneumatic valve and check / clean/ repair it.
Have fun
Avi
Nov 23, 2009 | Grohe Home
I have a Grohe shower head that leaks buckets (not an exaggeration). We bought the parts that we were advised to buy from Grohe, but even the professional plumber couldn't stop the leak or install the new...
sounds like you need volume controls lots of grohe fittings are strictly mixing valves not shut offs if this valve use to work then you need to find plumber familiar with grohe
Feb 21, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Dec 17, 2008 | Grohe Home
Home Logo
32 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
