Question about Sony KDL60EX700 60 in. TV
60EX700 r ed light blinks 5 times
How do I record and replay on my sony bravia 700.?
Hi
There appear to be several TV models that have the "700" in their model designation. I used the KDL-60EX700 and by going into the forum, here:
http://www.sony.co.uk/support/en/product/faq/KDL-60EX700
I entered the search term "record" and found several questions answered which should be helpful for you.
Cheers
Feb 07, 2015 | Sony Televison & Video
Sony Bravia KDL-60EX700 BAL Board / Flashing Green Amber
It sounds to be a firmware trouble. Will be best to contact the authorized service center for Sony, rather than trying to do it by yourself, as it is a very skilled work, need both concentration and previous experience. google.com/+GopakumarGopalan
Nov 24, 2013 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
My sony led tv model # kdl60ex700 blinks 6 times my sonny TV blink 6 times model # KDL-60EX700. What is wrong
I need more information like:
When it is turned on,
Turning off,
Connecting to something,
To close to the wall......Things like this to better you with your problem.
Aug 27, 2013 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
How do you adjust the clock on a C50? I lost my owners manual.. Thanks, Ed.
From the handbook...button 5 is the left one if u are sitting on the bike and button 6 is the right one.
"push buttons 5 and 6 simultaneously until the hour display blinks.
"adlust the hour display by pushing button 6
NB when button 6 is held down the display advances continuously,
"Push button 5 to highlight the minuite display.
"adjust the minute display by pausing button 6
"when you hsave reached the correct time then push button 5
this will take you back to the time mode.
hope this helps.
oscargilpin
Sep 28, 2009 | 2005 Suzuki Boulevard C50
4x4 won't engage. light blinks all the time.
The light blinks to alert you that a problem exists in the control module for the 4X4, contact expert Toyota Ed he is the service manager of a Toyota dealer, he knows his stuff
Nov 08, 2008 | 2000 Toyota Tundra
JVC tv i'art blinking timer
It is protecting you and itself with high probability.
Power supplies in modern electronic devices are designed to cycle if there is a fault in circuitry they are servicing and because of the design, also will not turn on completely if they are failing.
The older style of power supply was 'dumb' and unable to do this so could cause fires if the failure wasn't teh 'right' kind to blow the main fuse.
I agree with the manual; this is a job for a tech.
Aug 23, 2008 | JVC AV-32260 32" TV
PT-47WX54J 5-blinks between pasues - no audio or video
IC4511 is defective when the led blinks 5 times. that part is unavailable so you will need the entire circuit board.
Jul 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Sony KP57WS510 Blinking 8 times
You have a strt up problem. I found, in a similiar Sony Big Screen a couple of fixes. First thing to try is unplug the set from the wall for about 15 minutes and then plug it back in and retry the set. If this corrects the problem, I suggest you purchase a good ( Not a 5 dollar piece of junk) surge protector. ( One rated at 500-1500 joules. A good surge protector may prevent future processor lock ups. If this doesn't correct the problem, the problem lies in the circuit boards of the set. I found one problem in a Sony like you describe had a bad convergence chip and a burned resistor in the same board. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Televison & Video
Sony KDL60EX700 60 in. TV Logo
19 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
