Question about John Deere 670 770 870 970 1070 Compact Diesel Tractor Technical Repair Manual
No freeplay in clutch on 770
Engages when pedal is all the way out
Yam golf cart just clicks won't move!
Likely dirty contacts at the foot feed pedal AKA throttle pedal. The solenoid engages (clicks) but the dirty contacts keep the current from passing through to the electric motor.
1) disconnect battery, 2) Remove the pedal assembly and clean the contacts. 3) Reassemble and connect battery.
Sep 09, 2017 | Golf
Stairmaster Climber 4600 CL....The console seems to be powering up fine. We begin workout and after 5 or 6 'pumps/steps' per pedal it drops to the floor. Alternates left or right...no pattern.
Wrong site Dana. I do electronics, fix many things. But I would have to have your stair master to even begin. Since it alternates. Best guess it a bad plug. Next, bad solder joint. After that a bad chip on the PC board.
Jan 08, 2017 | Cars & Trucks
New clutch installed. No pedal, stays on floor unless I bring it back up with my hand. No resistance.
`Did it bleed, did fluid come out in a steady stream? Isn't there a spring to bring the pedal off the floor?
Check the linkage of the pedal to rod to the clutch master cylinder, make sure that is all together. Any chance the master has an internal leak and won't build hydraulic pressure down at the slave? If you get it bled, then watch the slave operation while someone works the clutch pedal. The piston on the slave should extend and push the clutch fork enough to disengage the clutch.
Jul 19, 2015 | Nissan Cars & Trucks
Have a problem no power when in gear from clutch slipping
Hi this sounds like the clutch is slipping , the cause could be a worn out friction plate commonly known (clutch plate) or it could be contaminated with oil either via a leak at the rear main seal or the transmission spigot shaft seal , it is best to replace the entire clutch kit , have a technician check the freeplay of your clutch pedal as a point of depature.
Hope this helps a bit,
Faldih Higgins
Automotive Diagnostician at Autocom SA.
Jul 21, 2014 | 2000 Daewoo Lanos
ABS engages without braking
Check all wheel sensors for broken wires, loose connectors or position of sensors in their mounting brackets.
Mar 29, 2017 | Cars & Trucks
Ford Fusion brakes stay soft after ABS engages
Then the system isn't working correctly
Mar 01, 2013 | 2007 Ford Fusion V6
The Clutch Engages at the end of pedal travel
Adjust your clutch pedal free play (clearance). It should be around 12mm only.
Oct 29, 2012 | Cars & Trucks
Can i adjust the clutch on a 1990 model toyota land criuser petrol ute
there are only two adjustment you can make on a hydraulic clutch set up and that is pedal hight and free play. To adjust pedal hight you rotate pedal stop bolt at top of pedal assembly to adjust the hight. To adjust freeplay you loosen the lock nut at the master cylinder pushrod and turn push rod in or out to the specified freeplay then you tighten everything back up
Feb 07, 2011 | 1990 Toyota Land Cruiser
John Deere 670 770 870 970 1070 Compact Diesel Tractor Technical Repair Manual Logo
32 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
