Fedders sfpmb07f2b diagram electrical
How many btu's does the fedders model # A6X05F2A have?
The unit should have a boiler plate behind the front panel indicating btu's and other electrical parameters. Look for it. Or Google the unit
5000 btu..
Jun 01, 2014 | Fedders A3X05F2A Air Conditioner
Our Fedders AirHandler Model#A24C1X keep 1 strip of heat when blower or nothing is on. have to unplug the red wire from NC on blower delay relay to stop it. blower relay Bd is new
Most of the time on Fedders unit one speed for heat comes off sequencer. This a low speed for heat. You may have bad sequencer. If your knowledge is limited about furnaces you may ahve to call service tech. But if you have some knowledge Replace the sequencer and follow woring diagram and you will be ok. Should solve problem. This time of year I replace dozens of sequencers due to this same problem. Rus
Nov 11, 2009 | Heating & Cooling
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Heat doesn't work on ac unit
u have to be more specific. is it gas or electric. If electric check breaker first. Gas check thermocouple
Apr 01, 2009 | Fedders Y Chassis AEY12F7E Air Conditioner
Does not start, manual nor remote
found fedders is bankrupt and another company is using the name
the tech there told me about the reset button on the other side of the plug, and the reset button worked
thanks
ALAN
Feb 11, 2009 | Fedders A6Y12F2B Y Chassis Room Air...
Fedders Y Chassis Quit Running
Bummer. I bought an AEY08F2G that put out no warm air and very little cool air. Fedders filed chapter 11 in August. They do not honor warranties now, and apparently offer no repair service. I was fortunate that I bought mine from Venting Direct, and the unit was still within the 60 defective return period. They told me that Fedders units are junk. They provided full credit for the unit (plus shipping costs) without requiring that the unit be returned to them. My advice is to toss it. Live and learn.
Aug 26, 2007 | Fedders Y Chassis AEY12F7E Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
