Question about Ladybug 2350 Tekno Steam Cleaner
Ladybug steamer will not turn on
Will not turn on. No lights
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
Shark floor steamer: Does not produce any steam and no lights are on.
Hi All
Shark steamer that the light is not on and will not heat up. I have found that there is a in line slow blow fuse in side. replace this fuse IF you can find one and the steamer will work. If you let the unit run dry and leave the unit on it will get hot and blow the fuse!
I am looking for the fuse myself. good luck! Dan FL.
Dec 17, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have an electrolux Enviro multi steamer which I was using this morning. I turned the steamer off for approximately 1 1/2 to do some shopping, and when I turned it on again, the steamer light turned on...
Problem fixed itself. Turned off for couple of hours so unit can cool down completely and when I turned it back on it started working again.
Dec 14, 2008 | Vacuums
T2100 S Ladybug Canister Steam Cleaner
Visit the Ladybug Ladybug 2200S Vapor Steam Cleaner page and scroll to the bottom. There's a link that says, "Download owners manual."
Oct 20, 2008 | Vapor T 2200S LadyBug Canister Steam...
Steam cleaner
Most upright steam cleaners like Hoover and Bissell, you put in the hot water, bissell does have a heater, but it only helps get the hot water a alittle hotter. But a model number would help.
Dec 12, 2007 | Vapor PC2200 Ladybug Steam Vacuum
Ladybug 2350 Tekno Steam Cleaner Logo
41 people viewed this question
Top Ladybug Vacuums Experts
JoeVacs
Are you a Ladybug Vacuum Expert? Answer questions, earn points and help others
