Question about Sewing Machines
Need service manual for carpigiani lb502g gelato machine ]
Wanting to operate an american 60hz machine on new zealand 50hz system. have provided the required voltage from a transformer. machine does not advance through production process. dont know if it is a frequency issue or an inherent fault within the recently imported second hand machine.
  • 10865 Answers
SOURCE: Need manual for singer serger model # 14sh654
Hi Wendy. Go to this web address and you can order what you need. http://www.sewingmachineparts.net/index.html
Please remember to rate my answer. thanks.
Posted on Feb 05, 2009
  • 16 Answers
SOURCE: Need manual for Huskylock 580
Not free solution but a quick one:
http://www.manualsnguides.com/search.php?cmarque=HUSQVARNA&modele=HUSKYLOCK%20580%20ED
Posted on Feb 14, 2009
  • 2501 Answers
SOURCE: Can I use my EuroPro 416 Sewing machine with 220V electricity?
A transformer will not change the frequency of the supply, only the voltage.
It may be possible to obtain a box of electronics to convert 50Hz to 60Hz, which would solve the problem.
A machine designed to run on 60Hz will run slower on 50Hz and may run hotter. If it burns out due to overheating, then a new motor designed to run at 50Hz should be fitted. You could have peace of mind if you fitted a new motor (which might be cheaper than an electronic frequency converter.
Posted on Jul 25, 2010
  • 4 Answers
SOURCE: need an operating manual for Simplicity, Model SW210
Sorry Angela, been looking for a manual for my Simplicity too but can't locate one either. If we don't contact manufacture for one, we may not get one. Unless someone out there has one to scan and share? Come on folks, help out!
Posted on Nov 19, 2011
Tally Girl
  • 1133 Answers
SOURCE: I have imported my american Elna sewing machine to Germany and use an additional plug now for the different currency. The machine light is stronger and the machine runs very fast now. How can I reduce
Are you using a transformer to break the current down from 250 to 110V?? Just putting a plug adapter onto the US plug end is not enough and can definitely damage your machine, I'm assuming its not an electronic machine as it would probably have fried the circuits if it was.
You may have to pay quite a bit for a good quality transformer but it will be necessary.
Posted on Dec 07, 2011
Is there such a thing as reduced fare positive space for retirees
none I have heard of but I am not associated with any airline check with the airlines
Nov 25, 2016 | Sewing Machines
Cs6000i. What caused it to pop and smoke?
You need to fix it. US machines are wired for 120VAC, 60Hz. Other countries are often 220V, 50Hz. Some machines have a switch that allows you to select. Some models have auto-switching power supplies that can handle either. Obviously yours did not. You most likely have damaged, at a minimum, the power supply. Once it is fixed, if it does not have a dual-voltage switch, you'll need to get a voltage adapter for it.
Nov 17, 2015 | Sewing Machines
What is the wattage of Kenmore 385.15202 sewing
The wattge used should be listed on the machine or it's wiring. If not, you should go to ( sears.com ) and find support. I do not see a problem using an outlet there from a public power as long as you have set the unit to use the correct cycles which is normally 50Hz or 60Hz. Some electronic devices such as yours will operate on either, but you will normally have a switch to manually set which Hz setting you need. The power you recieve from the utility will be either 50Hz or 60 Hz and you will have to set the unit to match the utilities rating. Best Wishes.
Sep 01, 2014 | Sewing Machines
I want to buy a brother pc-420 in australia, how do i achieve that?
I suggest to ,, on the internet look for sewing machine shops in your town in australia, & even look in the phone book in the yellow pages
do you have a hancock fabric in your area? they have sewing machines & sergers
Feb 11, 2012 | Brother PC-420
Bought a singer from the state but cannot be used in australia what should i do?
If it is an electronic or computerized machine, you are out of luck. USA has 110 volt 60Hz current, Australia has 220 volt 50Hz. A transformer can change 220 to 110 volts, but it cannot change 60Hz to 50Hz.
Sep 21, 2011 | Singer 4423 Sewing Machine
Are the memory cards for this machine still available? I purchased this model second hand and memory card 102 is missing and i would like to purchase it. I live in NZ
hi,
you will find ebay the best place to find card accessories for this machine. i have found heaps of cards for the 9000, including the 102. look for numbers with 3 digits for the 9000, 2 digits are for the older 8000, though they will work for the 9000 they are smaller and simpler designs.
ENHMC is another card label that works in our machines, made by amazing designs as after market cards. There are scanners and things second hand but they are a bit difficult. i find i get heaps of designs that you just pop in the machine.
Jul 20, 2011 | Janome Memory Craft 9000 Computerized...
Jul 25, 2010 | Euro-Pro Sewing Machines
Hello. Pfaff 2048 I have. I have it fixed two...
If you want to fix the sewing machine by yourself, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
May 19, 2010 | PfaFF Quilt & Craft Pro 7530
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
