Question about Sharper Image Turbo SM420 Handheld Steam Vacuum
Instruction manual homeimage steamer HI-6k203 user guide
User guide
Instruction to put it together
Bissell has the assembly instructions in the manual for the unit. Most Bissell manuals are available here: http://www.bissell.com/user-guides/ . The direct link to the manual for 1950 series Quick Steamer is http://www.bissell.com/user-guides/DownloadAsset.aspx?id=567 .
I hope this helps. Out of the box, the assembly is very simple. Put the handle on the lower body and secure with a Philips screw. The water tanks lift off and then get placed back on the body of the unit. (Use care when the tanks are filled with water.) See the manual for adding the bare floor tool.
Oct 15, 2015 | Bissell 1950-3 Quicksteamer Plus Vacuum
I need a manual for the oreck floor steamer
Hi! Since you didn't mention the model type of your floor steamer, i'm giving you the link where you can see the user's guide for all oreck floor steamers. So, access this link (http://www.oreck.com/Owners-Guides) and go to the floor machines category (under electric brooms).
I hope this will work for you! Have a nice day!
Sep 02, 2011 | Oreck steam-it Stick Vacuum
I have a Bissell Pro Dry steamer and cant find my manual. I filled the bottom tank with water and solution and it is pouring out. I havent used the cleaner in quite some time so I can't remember how it...
User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Aug 03, 2010 | Bissell Vacuums
Where can i get a bissell power steamer manual
BISSELL User’s Guides can be downloaded at www.bissell.com
May 30, 2010 | Bissell 1631 PowerSteamer ProHeat Canister...
Hello, I own a Bissell Pure Air Deluxe vacuum
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
Oct 16, 2009 | Bissell 3541 Pure Air Deluxe Bagged...
Scunci ss1000 handheld steamer
My Scunci MS 1000 heats and builds up steam, but the steam does not release from the spout when the release button is pushed. Plenty of pressure is built up inside (escapes when cap is opened). What is the problem?
Aug 03, 2008 | Scunci 52001 Handheld Steam Vacuum
Ok, perhaps I am an idiot!
If you go to this URL: http://www.dirtdevil.com/CustomerService/Manuals/default.aspx ...and enter the model number for your machine, then you can download a users manual. I would just give you the exact URL for the user manual, but I don't know your model number. If this helpful to you, please leave a good rating. Thank you! ;)
Aug 13, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Sharper Image Turbo SM420 Handheld Steam Vacuum Logo
139 people viewed this question
Top Sharper Image Vacuums Experts
Are you a Sharper Image Vacuum Expert? Answer questions, earn points and help others
