Question about Pioneer Audio Players & Recorders
Relay clicks, no display only the volume lights
When I turn on the power I hear the relay , it plays normal with no display.The volume control has the red light on.
Pioneer vsx-5700 s
  • 30 Answers
This is a common problem with a few of the Pioneer of that era (VSX-3300, 3700, etc). A secundary power supply line is faulty and it prevents your display from working. It is not an easy DIY, but a local tech should be able to fix. It is not always the same exact cause, as there are a couple transistors, a zener diode and a cap that can fail.
You can continue to use it without any detrimental effects on the unit, and can guess the settings.
Good luck
Posted on Aug 03, 2009
Hard time to start but when it turns on I hear the fuel pump relay clicking a lot and the idol start going up and down until the car turns off and by the way I got the track light on and the check engine...
Year make and model ?
Have you swapped the fuel pump relay with another ?
Its normal for the traction control light to come on if the check engine light is also on.
Have you checked the engine computer for trouble codes ?
Mar 27, 2015 | Cars & Trucks
Double relay
Check car relay and check car problem with obd2 diagnostic tool, it is quickly and easy at OBD Tools 365 Days Shop
Find the particular relay you want to test. Depending on the circuit it controls, the relay may be located under the dashboard or inside the engine compartment in a junction block.
Turn the ignition switch to on to energize the particular circuit you are testing, if necessary.
Connect the alligator clip from a test light to any good ground on your vehicle. Probe the wire coming out of the relay and going to the component with the tip of the test light. If the bulb in the test light glows, there is voltage, and your relay is working properly.
Probe the wire or wires feeding voltage to the relay with the test light following the same procedure used on the previous step. If the light glows, there is incoming voltage. Otherwise, the relay is not receiving voltage. Check the voltage source.
Switch the ignition key off. Unplug the relay from its electrical connector, making sure not to break the locking tabs on the relay.
Identify the relay's power and control terminals. Some relays show a circuit diagram on top of the case to identify these terminals.
Check for continuity between the two power terminals using an ohmmeter. There should be no continuity. If there is continuity, replace the relay.
Connect a jumper wire between the battery positive terminal and one of the control circuit terminals on the relay. Connect the other control terminal to ground with another jumper wire. If you do not hear a click as you make the second connection, reverse the connections. If you still do not hear a click, replace the relay.
Connect the jumper wires as you did on the previous step. Using an ohmmeter, check for continuity between the two power terminals. If there is continuity, the relay is working properly. Otherwise, replace the relay.
Jan 13, 2014 | 2001 Peugeot 206
My 99 caravan has no running lights but all other lights work. i found 2 fuses under dash but no power going to them. it is not equiped with day time running lights. i can hear relay clicking when turned...
Park lamp relay location under hood fuse box. Park lamp relay is controlled by the BCM - body control module .Fuse #22 40 amp powers park lamp relay .
Dec 26, 2017 | 1999 Dodge Caravan
Just installed a new frigidaire electric range model LGEF3045KFB. The plates (smooth surface) work ok, but the oven is dead including the electronic display, the oven light etc. When I first turned on...
The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other side of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Here's what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. especially these small relays
Dec 05, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Speaker protection fault on rx-v557
Hello, you must first tested with a voltmeter in DC entrance if you have a DC voltage on all the terminal outlet speaker, normally you must obtain 0Vdc+/-50mV on each out speaker with control volume to minimum, you can stay or remove the speakers during this test.
BY
Sep 04, 2008 | Yamaha RX-V557 Receiver
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Unit won't power up completely
The clicks you hear are the relay that completes the circuit for 110V AC to the main power transformer. Mine had the same problem and here's how I've gotten it to work. A lightning strike near our house caused it to fail, and I traced it to the power transformer relay activation circuit. The tuner and amp were fine. I found a bad transistor in the relay circuit, but didn't have a replacement on hand, so I soldered a jumper wire across the relay switch connections on the power transformer circuit board. This connects the 110V AC directly to the power transformer. DC Power to the amp and tuner circuits will still be controlled by the power switch, but the transformer will be supplying all the AC voltages to the main board. If there is a real problem with the circuits that load the transformer or the transformer itself, then the fuse will blow. If the fuse doesn't blow then I suspect the problem is just in the power sequencing circuit itself, that is not needed for operation other than to make the unit "Energy Star Compliant". A lot of electronic items have a transformer that is not switched, and only fused, so that the supplies are available at all times.
Jan 24, 2008 | Audio Players & Recorders
308 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
