Question about Ford 8N Tractor
Holding tractor up when droping the oil pan
1948
2 Suggested Answers
yotaguy
  • 232 Answers
SOURCE: trainsmission oil
No,becuase generally by the time you need to change the fluid the filter should be replaced also.
Posted on May 09, 2009
I doing a engine rebuild to a 1948 8N. I'm trying to do it in frame. How do I take the oil pan off without the engine falling
got a shed girder or cross beam in the shed strong enough
to support a chain block
have see it done under a strong tree branch and rope and pulley
Nov 10, 2016 | Cars & Trucks
Oil pressure droped to 0 , and than bonced up and down . loss power and the motor shut off . it started back up but no pressure or power
oil pumps are located in the oil pan area by dropping the oil [pan this shouls access the pump when you get the oil pump the parts outlet will bring up a diagram of your system get a copy
Sep 04, 2012 | Cars & Trucks
Oil pump
it's not easy even for pro mechanic.
oil pan has to be droped , in order to repl. oil pump.
but I think you pump is ok , the problem is o-rings between oil pan and cyl. block , that's were you loosing oil pressure , which is again - oil pan has to come out.
Can't be done by a careful rookie.
Apr 30, 2010 | 1999 Volvo S80
How do I chamnge the oil in my Craftsman lawn
There should be a pipe OR quick release valve coming out the right side at the bottom of the engine where it bolts to the frame. Most of the Craftsman riders I have worked on, had a long pipe with an elbow at the end of it and a plug in the bottom of the elbow for draining. Turn the wheels all the way to the left to allow enough room for a collection pan. It holds less than 2 quarts so the pan doesn't need to be too large
Sep 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
On a 1948 Ford 2N tractor, how high should the fluid level be in the transmission? Looking in the fill hole next to the shifter, it seems that the level is fairly low past the gears. How high should it be?
My brother has one of those tractors too so I called him and asked him and he said that he has his oil level up into the gears but he also said that you can go on Google and find out any info that you need on those tractors. Hope this helps you out somewhat.
Aug 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Oil psi droping off on gage,lifter noise off and on
Its very easy. Removal Oil pan, Tube from oil pan plugs into oil pump..Remove bolts ( located @ front of crank shaft) The pump is Geared with #1 Crank so should back same way!.
Jun 02, 2009 | 1999 Chevrolet Silverado 1500
Bearing on cam
you can not acess cam bearings from the oil pan. I don't want to see you get taken for a ride.
Oct 18, 2008 | 1996 Ford Taurus
Ford 8N Tractor Logo
26 people viewed this question
Top Ford Toys Experts
Philip Doherty
Level 1 Expert
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
