Question about Chevrolet Silverado 1500 14920-88 Tonneau Cover Tuff Tonno
1988 chevrolet silverado 1500 losing power
My truck losing power and back firing
    Scholar:
  • 77 Answers
Sounds as though the in-line fuel filter is stopped up. It is typically located underneath the truck on the frame rail. It has a inline fitting on each end.
If stopped up it can still run, though not very well. When driving the truck, try pressing the throttle full throttle and see if it starts to slow, or loses more power. Easier to determine if on a steep hill and then accelerate. It can also be checked with a fuel pressure gauge hooked to the shrader valve on or near the intake manifold.
Another note: A clogged catalytic converter can do somewhat the same symptom.
This is not typically the way most will do it, but without a diagnostic can be a way of getting a general idea.
Posted on Jan 05, 2015
    New Friend:
  • 30 Answers
Before buying any parts you should do the following: inspect plugs, wires, cap, rotor, wire connections to distributor, alternator,starter, battery, belts. Make sure each part is tight and secure. Replace parts that need to be replaced an checking performance after. Next if everything looks ok, take plug out of cylinder#1, set piston to top dead center on compression stroke. Remove cap on distributor, rotor should be pointing to #1 cylinder, if not depending where rotor is pointing you could have the following problems. 1. Distibrutor loose. 2. Bent distributor shaft.3. timing chain skipped a cog 4. Inside distributor is corroded or parts have stuck or come loose. You could have set #1 cylinder in the wrong position. A compression test should be done first before replacing changing timing chain # should be close if out by a lot and the motor has high mileage year of vehicle and condition body wise should be considered , as this could end up being a money pit.
    Master:
  • 710 Answers
Check fuel supply
Posted on Sep 01, 2014
My2002 sierra with a4.8 with a good battery, all my dash lights and cd player come on but the truck doesnt turn over right away sometimes it takes 5-10 minutes 2 start of repetitively turning key over
battrey is good but truck makes no sound and wont even click
www.cargurus.com > Questions > Chevrolet > S-10
CarGurusbattrey is good but truck makes no sound and wont even click ... Asked by Jennifer May 15, 2013 at 03:21 PM about the 2002 ... quite obviously the amps aren't getting through~ how do you know the battery is "good". the date ... If it turns over your power and starter are good but the ignition circuit ... Used GMC Sierra 1500".Missing: a4
Intermittant Failure to Start : Chevrolet Silverado 1500 ...
repairpal.com > Problems > Chevrolet > Silverado 1500
first start engine turns over alot. 2000 Chevrolet Silverado 1500. Hard start. When starting my truck it often takes two or three attempts. It kicks over but does not ...Missing: a4
Chevy Silverado and GMC Sierra Starting Problems - Car Forums at ...
forums.edmunds.com > Chevrolet > Chevrolet Silverado 1500
Oct 20, 2008 - 30 posts - ‎19 authors
i got a 2001 silverado 1500 and it wont start it turns over and fires and .... Put the key in and the truck barely starts due to the battery being weak. .... If it was really 8, the lights would be dim? .... I have a 2002 GMC Sierra 4.3L 2WD. ... I bled the fuel filter looking for air, but good fuel came out the top bleede ...Missing: a4
Jan 01, 2016 | 2002 GMC Sierra 1500
2003 chevy truck losing power
If it happens after it cools down, then warms up, look at the catalytic converter. Have the codes read.
Dec 14, 2015 | 2003 Chevrolet Silverado 1500
Problem with 2001 Chevrolet Silverado 1500 but when i depress throtle five tims to reset message senter it starts and runs great and then if i do that again the problem returns
Sounds to me that the starting is faulty, drawing the power from all your other things like computer, message center, etc. Causing everything to lose its memory.
Dec 19, 2013 | 2001 Chevrolet Silverado 1500
Need firing order for 2000 chevy silverado 1500 4.8 liter
Here is a schematic of your engine layout and the firing order.
images?q=tbn:and9gcswn90sg795ufflsdpib9lesujljru6h1jhqveca71tvy2urgpb Firing order:- 1-8-7-2-6-5-4-3
Mar 11, 2011 | 2000 Chevrolet Silverado 1500
1988 chevy silverado wont fire. Already checked the ign mod next is the coil. What else might cause it not to fire?
internal parts of distributor body ...(hall effect generator/ pick up or rotor, cap contacts as they apply to your vehicle)
Oct 02, 2010 | 1988 Chevrolet Silverado 2500
Need to know firing order on 1999 Chevrolet Silverado 1500 v6 and need firing order diagram
1999 Chevrolet 1500 P/U 4WD 4.3 liter V-6 VIN "W"
Hope this helps (remember rated and comment this).
Sep 04, 2010 | 1999 Chevrolet Silverado 1500
Car after hour of driving loses power. Only goes
Check fuel pressure when truck acts up and check for spark to rule out bad ignition module or coil.
Apr 29, 2010 | 1999 Chevrolet Silverado 1500
What is the correct firing order for a chevy 1989 5.7 engine on the distrbutor cap
1989 Chevrolet K 1500 P/U 4WD
5.7 liter V-8 VIN "K"
Firing order is 1-8-4-3-6-5-4-2
Distributor rotates clock wise and #1 is at the 5 O'clock position "post by the # 7 cylinder.
Cylinder # passenger side front to back 2-4-6-8
Cylinder # dirver side front to back 1-3-5-7
Dec 09, 2009 | 1999 Chevrolet Silverado 1500
Chevrolet Silverado 1500 14920-88 Tonneau Cover Tuff Tonno Logo
77 people viewed this question
Top Extang Vehicle Parts & Accessories Experts
Frank Magliocca
Are you an Extang Vehicle Part and Accessory Expert? Answer questions, earn points and help others
