Question about GPX D1816 DVD Player
Wrong regional disc - GPX D1816 DVD Player
  • mperona Jul 16, 2009
    Thank you, dantechcom, for your answer that you needed my dvd player make & model # to change the codes. I actually found the decoding info I needed on another website, so I changed the code (to play all regions) & now watch DVD's just fine! Again, thank you for your help!
I have also a problem, can you help me to reset the region code?
Posted on Aug 22, 2009
    President:
  • 846 Answers
Hello mperona,
The reason you are receiving this message is due to the region settings on your dvd player. Dvd players use region settings to allow them to only play dvd's from certain parts of the world. Your dvd player's region settings do not match the region code of the dvd disc.
The only way is to make your dvd player multi region....you will need to post the make and model of your dvd player so I can search for a solution that will work.
Thank you for choosing Fixya!
Posted on Jul 15, 2009
What does the message Wrong Regional Disc mean
The disc you are attempting to play is intended for use in a certain region. You have to choose between getting a disc for the correct region or making your player region-free.
Dec 22, 2014 | Televison & Video
Wrong region DVD player won't play a disc
Can,t be done with the one you have,
Nov 10, 2012 | Philips Televison & Video
When I put movie in it says wrong region
Home theatre systems are usually made and distributed based on regions. Usually there are about 7 regions and players are usually distributed to each region based on the type of disc which will be distributed in that region.
The disc you have is supposed to be distributed to a different region but has found its way to you. Usually the formats on which the discs are made are usually different from region to region. Although there are methods to change these devices to work with any unit.
Hope this solution has been helpful;?
Jan 02, 2011 | HTC Audio Players & Recorders
Wrong disc
this problem is normally a fault due to using a dvd disc that is not from your country region. check the dvd box and make sure the region code matches your country that you a veiwing it in.
Jul 12, 2010 | Sungale DVD-2026 DVD Player
Region problem
HELLO!
TRY THIS!
Turn on the player
Make sure disc tray is Open.
Press 9 9 9 9 on the remote, do it slowly.
Press what region you then require.
Press 0 (zero) for multi-region/region free playback.
When you are trying to play back a disc other than the region the machine is set up for, you will get a Wrong Region message.
ENJOY! (:-)
Oct 04, 2009 | Philips DVD625 DVD Player
Sony dvd wont play certain discs
yes the sony dvd players is made for certain regions it wont play other discs that are not either region one or two new zealand i think is region 3
Apr 15, 2009 | Sony Televison & Video
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
Coby 224 wrong disc
you can reset the settings through the menu, its under the advanced option in the menu. however, its not a regional error, if it was in the wrong region, it would say wrong region and not wrong disk, try putting the region back to 1 or 0 or 9, 1 is USA, 9 and 0 are all regions.
Jul 06, 2008 | Coby DVD-224 DVD Player
Wrong region code if zone 2 disc is inserted
MMDV2 Region change procedure:
1) Turn Unit ON
2) Make sure there is NO disc in the unit.
3) Press TITLE on the remote control.
4) Press 0,1, 6, 7 and then ZERO for all
region, 2 for region 2 etc
Feb 26, 2008 | Audiovox MMDV2
GPX D1816 DVD Player Logo
405 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
