Question about Rival Automatic Steamer/Rice Cooker 4450 GW
Where to put water
Instructions
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    I've lost the instructions on how to use my slow cooker. Do I need to put water in the base?
    Which base are you referring to? The removal black base yes, you need to add water according to what you are cooking for example a stew, a chicken, beans etc., The cooking element, which is the base after you remove the black base in which the glass cover fits over you do not need to add water.
    Oct 15, 2010 | Rival 3040-VG 4-Quart
    Help .Do i put water in my slow cooker!!
    do not put water in to the metal pot. place the ceramic pot inside the housing or metal part add your meal and set to high or low depending on how long you will be away and enjoy your food.
    Jan 26, 2010 | Crock Pots & Slow Cookers
    I have a Rival smart pot given to me no instructions do i need to put water in the base part and then the ceramic and how much water do i need?
    You do not put water in the base. Just put your ingredients in the crock part and whatever liquid the receipe calls for. you can probably find the instruction manual on crockpot.com or call and ask them to send one.
    Nov 15, 2009 | Rival 38601 Smart Pot 6-Quart
    Never used a crockpot
    No do not put water under the removable bowl. Do you have the manual for it. If not get me the make and model # and I will try to get you the manual
    Apr 06, 2009 | Rival Crock Pots & Slow Cookers
    Royal doulton multi cooker
    not a solution as such but u can use it as a slow cooker on low
    put it on put veg in add water then meat leave about 1 inch gap from lid and put on low for a few hours dont let it boil dry
    Oct 15, 2008 | Crock Pots & Slow Cookers
    General Electric 6-Quart Slow Cooker double bowl
    According to instruction book: To use Double bowls in the crock water must be used. Otherwise crock may overheat and crack.
    1-Pour one quart of water into the crock. Prepare recipe according to instructions. Place food in the bowls.
    2-Place both bowls into crock. Cover & cook.
    To Use Double bowls in the base (without crock)
    1-Prepare recipe according to instructions. Place food in bowls.
    2-Place both bowls into the slow cooker base. Cover and set control knob to desired setting.
    Hope this helps.
    JL in CA
    Jul 03, 2008 | GE 106851 6-Quart
    To add water or not to add water????
    Slow cookers do not need water in the base unit to cook the food in the ceramic insert. The ceramic insert gets hot from the base and cooks the food. Here is a good guide to cooking with a slow cooker. enjoy
    http://busycooks.about.com/library/print02/ncrockpot101.htm
    Dec 06, 2007 | Select Brands SC-25 2.5-Quart
    Crock Pots & Slow Cookers Logo
    Top Rival Crock Pots & Slow Cookers Experts
    Jerry Greenberg
    Jerry Greenberg
    tsalagi152
    charles
    Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
