Question about Canon PIXMA MP780 All-In-One InkJet Printer
My PIXMa MP 780 will not print.
I get a "Check printer" error. I have checked the ink tanks, the paper feeds, and everything else. I can find no apparent reason for the problem.
  • georgecar Jun 14, 2009
    My printer won't print any b&w documents either.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 127 Answers
Hi Sir,
Try the following steps. first of all we need to check the hardware of the printer, this can be accomplished by simply making a black an white copy of any document from the printer. it checks the scanner lamp as well as the printing. if everything goes fine,the printer is ok,its solely the issue with the software,hence move to the following steps,
1.goto the Start button--->control panel-->printers and faxes >now check the status of the printer icon,do you see any printer icon. if its greyed out,it could be a connectivity issue. unplug the cable and replug it to a different USB port. Check if your computer gives a "Found New Hardware" Balloon on the right hand corner of the screen.
if not
goto Start-->run--->type devmgmt.msc in the run box. this should open the device manager for you. if you see any yellow exclamation symbol beside the entry,it shows that the drivers aren't in good shape. so if your printer came with a cd try updating the printer driver or else download the drivers from the internet and install it.
At any point if you need a free assistance from a technician, you may log into www.techbuddies.org as their technicians provide freee technical support,you can leave a message on their chat and they'll get back to you ASAP.
For further clarifications you may reach me at fslahmed@yahoo.com
Posted on Jun 14, 2009
My printer shows E 2 7. how can i fix it?
i believe on this model the error code means that the ink tank is full...
http://www.mediafire.com/?s2pa54m5z2wqwru
this is a link to my hosting site where you can download the software reset tool for a the MP models...
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Additional information error codes for the MP models...
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Aug 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Cannon PIXMA MP 780
6A00 means the cleaning assembly on the right where the printhead parks is jammed. Usually just gummed up with old tacky ink. To clean it requires taking all the covers and scanner off of the top and removing the print engine to access the purge assembly. It can be washed in a sink but it's a messy job.
Feb 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP 800 When it prints it just feeds the paper through there is noting printing on the paper. How xan I fix it
clean the printer head using the printer software tools, do these 3 to 4 times then print a page, if still work check your ink level, if you have a full ink cartridge and there no printer error aside from this have your printer head check by a qualified tech
Nov 22, 2009 | Canon Pixma MP800 All-In-One InkJet...
Won't print black ink text; looks like faint watermark print; ran all maintenance check several times (nozzle checks, etc)
Remove the black cartridge and soak it with an alcohol free window cleaner soaked paper towel let it sit on the towel for a good thirty minutes then wipe clean and put back in printer run nozzle check if necessary.
Oct 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Cartridge is jammed
I have a canon pixma 780. It was working fine then I had a paper jam and message "Cartridge jammed" I removed paper with no difficulty-piece was not torn.Now it will not print at all Paper feeds through but no printing in any colour
Mar 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My printer will feed paper, but no ink is printed..
i im  josh in cebu phils.may i help you? Friend the printer that prints and without ink appears even though not run out of supply. the problem is not the ink  but the tank lever that carries the cartridge.there maybe stuck dried ink on it came from previous ink installed that drain on the lever. Solutions: 1. try to remove all the ink and clean the lever with a soft cloth. 2. go to settings and perform the head cleaning and nozzle check. 3. do the printing repeatedly until the ink comes out. thats all friend good luck hope i helped you.
Mar 14, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
MP 780
plz check your ink level it might be empty,if it is not then try by reinstalling the drivers, if the problem persists than you have to send it for servicing
May 19, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP 610 Pixma Printer
hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
May 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Mp780 waste ink full
CANON MP 780 WASTE INK COUNTER RESET
Enter Service Mode : Menu – Scan – Copy – Scan
Select #7 PRINTER in the service mode, and
input “0” at # 5 INK ABS CAPA.
Jan 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
26 people viewed this question
old marine
old marine
