Question about Eagle Creek Tarmac 25 Wheeled Upright Luggage
The zipper is stuck
Stuck
I need a zipper foot for my Pfaff 1047. Where cn I find one?
Pfaff - Zipper Foot for IDT™ System (1)
www.pfaff.com/en-GB/Accessories/Zipper-Foot-for-IDT-System
The Zipper Foot is the most important zipper tool and will help you stitch the zipper perfectly in place. When attaching any zipper, it is important to sew right next ...
Pfaff - Invisible Zipper Foot
www.pfaff.com/Accessories/Invisible-Zipper-Foot Invisible zippers are the least noticeable of all zippers. As the name implies, the zipper is hidden in a seam, becoming virtually invisible. This makes it a popular ...
Pfaff 1047 Sewing Machine Parts - Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts Rating: 4.8 - ‎91,711 votes
Results 16 - 30 of 77 - An Online Pfaff Parts Superstore, We also supply 1047 manuals, presser feet and accessories. Fast, free shipping over $75. zipper foot for my Pfaff 1047 Google Search
Feb 27, 2017 | PfaFF Sewing Machines
Pfaff Expresions 3.0. Using my zipper foot with 3 teeth. But can not get the needle to position to sew close to zipper
Um, not sure what presser foot you are using--there are several.
If it is the invisible zipper foot, there is a groove in the bottom of the presser foot that straddles one strip of zipper teeth which positions it close to the needle. Zipper foot #4 snaps to either side to enable the needle to be close to the zipper teeth. The Narrow Adjustable Zipper/Straight Stitch and the Non-Stick Zipper Feet are moveable left or right.
Pfaff Presser Feet
Oct 01, 2016 | PfaFF Sewing Machines
I can't make the zipper work.
look at the zipper, see if there is any material stuck in the zipper, slowly move it back and forth and trying to remove the material from the zipper.
Oct 07, 2015 | Clothing
The zipper on my Asos dress split and it is stuck in the middle of the zip with both ends open. Now I can't zip it down
Hold the zipper that both sides are parallel then go upwards then downwards . Once u go upwards look it could be a little thread stuck in it .
Coz it's a plastic zipper it happens just get it replaced .
Aug 30, 2014 | Sewing Machines
I have an LG washer that is about 10 years old. Never had a problem with it until today. Several minutes into the wash cycle, the drum tries to turn but can't. It makes a high pitched sound and tries to...
Your guess seems right as the damaged zipper could be stuck within the drum or movement and could cause friction to the movement. You can remove power and try to check on the free movement of the drum, if not the drum assembly must be removed and reset.
Sep 27, 2013 | LG WM-0532HW Front Load Washer
Heater on my 01 tahoe gets stuck on
check your HVAC fuses underneath the steering wheel and or hood. if not the problem, remove the bezel piece as directed and unclip the attachment (see if the knobs are aligned (on track) with one another. its very easy over time for them to slip. its like a zipper. sometimes zippers get kinks as well as the knob. hope this helps
Dec 04, 2011 | 2001 Chevrolet Tahoe
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Jun 19, 2009 | Janome Harmony 2039 Mechanical Sewing...
REMOVE FRONT PANEL - ZIPPER PARTS STUCK IN DRUM GUIDE.
I found the parts manual on line at GE Appliances.
The replacement parts for the top indicated pictured two clips holding the front of the dryer in place.
I tried a narrow screw driver on the clips and that released the top.
With the top off, removing the front panel required removing two screws, lifting the drum and pulling slightly on the front panel.
After removing the wires from the door switch, I was able to find the broken zipper, clean out the fan, remove excess lint and reassemble.
Dec 06, 2008 | GE DBL333EBCC 5.7 cu. ft. Electric Dryer
Zipper is really stuck
sometimes dirt and debree can get stuck in there, try saturating it with a strong penetrating oil like PB Blaster, available at your local auto parts store, and let it soak in for about an hour and use a pair of pliers to get a good grip.
Nov 23, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Eagle Creek Tarmac 25 Wheeled Upright Luggage Logo
413 people viewed this question
Top Eagle Creek Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you an Eagle Creek Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
