Question about Kenmore 22422 Top Load Washer
Model nbr 110-92580100 ser cd 3347297. wouldnt
Put load of wash in started machine. there was a ticking noise . came back when done the clothes were damp. so i put back on spin and there was a loud noise and it wouldnt spin. can you help model 110-92580100 and serial cd 3347297
  • 331 Answers
Your kenmore sounds like it lost the coupler do you feel ok opening the machine and inspecting the part?
the loud noise may be the coupler. I think your timer is working ok. because it goes through the cycle..
If you inspect it to be a bad coupler you can go here www.techray1.com and click on the link
let me know
Posted on Jun 14, 2009
Water going in 2 the machine after the load is finished and the clothes r taken out
bad water inlet valve or control board? foes it do it even after u unplug it? if so then its ur water inlet valve if it stops after unplugging it its ur control board
water-going-in-2-machine-after-load-cs4uo0ksqeekdm4wcgxnqiuz-3-5.jpg ALSO CHECK THE WATER PRESSURE SWITCH BELOW
May 27, 2015 | Tricity Bendix AW1000W Front Load Washer
Can you tell me what nf means
No fill error. The washer thinks it's taking too long to fill up with water
Dec 14, 2014 | Kenmore Elite 45986 Front Load Washer
I have a Affinity Series fafs4272lw. When I got it, I could put about 3/4 full of clothes and now it makes clunky noises like it is hitting the side of the washer. I had the repairman out he said I put...
It easy to get out of balance if stuffed too much. The load sensing during the start rolls the clothes back and forth to balance the load. If its packed tight it won't do well.
Oct 16, 2013 | Frigidaire FAFS4272LW Washer
GE Washing machine model WCSE 416OB is making a loud noise when spinning and not fully wringing the water out of the clothes--what could be the problem?
I fyou have a well balaced load and it is not banging side to side or doing the wash machine dance then it is probably the trasnmission or coupler. IF you want to spend some money or lots of money to have it replaced it's up to you it wouldnt hurt to have a authorized techichian take a look at it. If it is and it is nt worth fixing then take a look at a front loader wash machine you cant go wrong with one of those as it gets more water out of your clothes which means less time int the drier and saves you allot of money.
Cheers
Al
Sep 11, 2009 | GE WBSR3140DW Top Load Washer
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Aug 30, 2009 | Kenmore 22422 Top Load Washer
The machine fills and drains on wash cycle but willnot spin
C1. Your motor was stopped due to overloading, inbuilt device, reduce weight of clothes (put less clothes). Press 'stop' & 'cancel' to clear the display.
How abt a good rating? Thanks
Mar 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer makes loud noise but aggitator doesn't even turn
a load of Jeans or pants is hardest on washing machines , you probably broke the belt for the aggitator
Dec 14, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Um..... not quite sure....
Most likely the transmission on the motor has seized and will need to be repaired. Look under the washer, if there is black grease on the floor then its time to replace the motor and/or the transmission. If you have seen smoke then its probably the case.
Jun 20, 2007 | Whirlpool LSB6200KQ Top Load Washer
Machine won't work. kenmore 90 series
Might be a broken motor or a blown fuse. I would suggest having your machine looked at by a specialist. If it's old, you might consider replacing it.
Mar 21, 2006 | Kenmore 15864/15862 Top Load Washer
Kenmore 22422 Top Load Washer Logo
260 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
