Question about Michley Lil Sew Mechanical Sewing Machine
Thread breaks when stitching. I think there is problem with the tension
How do I fix the tension
How do I fix the tension on a 140s smarter by PFAFF sewing machine?
Depends what exactly is happening with the tension.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
HINT: ALWAYS RAISE the presser foot when threading the top thread!
Jun 25, 2017 | PfaFF Sewing Machines
My pfaff 1475 CD thread is loopy on bottom and breaks on top.
Look very closely at your sample stitching and determine which thread (top or bobbin) is looping and which is breaking. That will narrow down where the problem exists.
A top thread that loops and makes thread "barfs" under the fabric is generally an upper thread tension problem.
Try: Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Set the upper tension to the midway point (probably will need to tweak this tension depending on your machine).
Sewing Machine Tension
Apr 12, 2017 | PfaFF Sewing Machines
My stitching on Brother ls 2020 sewing machine is loose. How do I fix the problem
Without more description of the stitch symptoms, the only suggestion is that the tension is too loose. Whether it is the upper, bobbin, or both tensions, we cannot answer without more information.
Dec 31, 2016 | Brother Sewing Machines
Lower thread tension too loose
sorry without knowing your MAKE machine I can suggest nothing helpful
Aug 28, 2016 | Sewing Machines
How to fix tension pls
if your talking about the tension dial, it may need to be replaced
Dec 23, 2015 | Sewing Machines
How do you fix tension on pfaff 5.0
What tension problem are you having? You can adjust the top thread tension in the tools menu normally on most auto tension models. The bobbin tension is adjusted by the tension spring screw.
Apr 10, 2015 | PfaFF Sewing Machines
How to fix my coverlock from skipping stitches
Looper timing is probably out, maybe even a damaged looper. Take it in for servicing.
May 14, 2014 | Sewing Machines
Embroidery not working correctly
Well, before I did all that (which may be necessary), I would take a piece of UNWAXED dental floss or hand embroidery floss and floss between the tension disks. You mentioned that you were suddenly breaking threads; there may be lint or loose threads or both seated between the disks, preventing the thread from seating properly. Then,
I would take the embroidery unit off and try to do some sewing with it, to see what results I got. If you can catch and bring the bobbin thread to the top with the top thread, I am doubtful that your timing is off. Sew a line of both straight stitch and zigzag stitches, and see if the stitches are balanced. If not, you may have a bobbin tension issue, and if so, most bobbin cases can be adjusted.
I think you'll find, though, that things will improve considerably when you have cleaned out the upper thread path and tension disks. Make sure when you do that, that your foot is raised, so that the disks are spread. Oh, a drop of sewing machine oil wouldn't hurt either--generally you should put a drop of oil for every 5 hours of embroidery.
Please get back to us to let us know!
Mar 14, 2014 | Singer Quantum XL-6000 Computerized Sewing...
Michley Lil Sew Mechanical Sewing Machine Logo
100 people viewed this question
Top Michley Sewing Machines Experts
erebooni
Level 1 Expert
Robin Hill
Robin Hill
Are you a Michley Sewing Machine Expert? Answer questions, earn points and help others
