Question about Anets Fryer- Gas- Floor Model- Legs- 35-40 lb
My fryer has a pilot but wont turn on
I have pilot flame when i hold the pilot button down but when i realese it and turn it after holding it down for more than 30 seconds and the pilot blows out and the fryer wont turn the flame on
Lighting the pilot, starting the fireplace
Turn on the gas, hold the pilot flame button down and light the pilot flame, continue to hold the button for at least three min's, release the button pilot should stay lighted.
Jan 06, 2017 | Majestic Heating & Cooling
Deep fryer wll not ligth
Frequently customers do not hold the pilot "lite" button down long enough for the fryer to light. We normally instruct them to hold the pilot lite button in for some time, then light it, and after it lights, turn thermostat back to your regular setting. People get alarmed that they have to hold the button in as long as they do, but that is what it takes to light these units up, so hold it in longer, then light. Once we give these instructions, they normally do not call back in, and manage to light it ok Good luck to you, Susan REO
Dec 14, 2011 | Imperial IFS40 Deep Fryer
Need to know where to light pilot
Normally, it's under the fryer, inside the door...The issue almost always is you have to press the button down long enough for the sensor to tell the fryer to light....There are 3 or 4 burners in the bottom of the frypot on top and under the fryer is the pilot to light these all up...Look for the gas valve, turn the gas valve to pilot, and press and hold it down, put flame to pilot and release button when flame is self standing... Then turn to on position. If you have other issues, call the Vulcan company themselves, and they will help you further.... Susan Restaurant Equipment Outlet, Cinc, Oh www.restaurantequipmentinc.com
Aug 20, 2011 | Vulcan EF3 Deep Fryer
I have the AF45 fryer. I cannot light the pilot on this fryer. I have tried all possible solutions to this but still wont work.
Normally, on manual gas fryers, people don't hold down the light pilot button long enough for the sensors to heat up, to tell the pilot to light.... That's our number one complaint, and number one service call, and it's almost always the same thing;..... Hold the button down much longer, then try to light it... If you still have trouble, call our service tech, Ray @ 888-542-5959, at Restaurant Equipment Outlet, Cincinnati, Ohio. Thanks, Susan REO
Jul 16, 2011 | American Range AF45LP Deep Fryer
Trying to light the pilot light on deep fryer when i push button in it lights but when i let go of button pilot light goes out what am i doing wrong
If the pilot flame does not hold after releasing the button for at least 20 to 30 seconds, try to clean the thermopile and tighten all wiring connection on gas valve, thermostat and hi limit the repeat the process. The thermopile must be heated by pilot flame in order for it to generate small amount of voltage to open the pilot valve.
If this does not correct the problem, try replacing the thermopile.
May 24, 2011 | American Range AF45LP Deep Fryer
Hi i have a new imperial fryer and im tring to light it and cant seem to get it to work. any idea on how to get it working?
Have a lighter handy (I use one of the elongated ones for caravaners)
in-between the burners is a pilot light (top right) keep the lighter flame where the gas comes out.
On the right hand side of the fryer at the bottom is a gas valve with a little black knob.
Press and hold the black knob in and gas will come out of the pilot light and ignite by the lighter flame. You need to hold the button in for quite a while. (until it stays lit)
When it stays lit depress the little black knob and turn it anti clockwise. Gas comes out of the burners and ignites from the pilot light. When it reaches temp. it will cut out.
To turn it off turn the little black knob clockwise. To turn the pilot light off, push and turn clockwise.
Mar 04, 2011 | Imperial IFS40 Deep Fryer
Pilot wont light
If the pilot light goes out when you release the primer,then the thermocouple is bad.You can try to adjust the thermocouple,if it can be.It needs to be in the pilot flame.If the thermocouple is not in the flame,it will not stay lit.If you can not get the pilot to light at all,with the primer pushed down,then replace the regulator.To light the pilot light,you need to turn the dial to pilot.Then press the primer button down and hold it.The primer is either built into the turn knob,or it is a res button.Hold the primer down,and light the pilot,continue holding the primer down for at least 40 seconds.Then release the primer slowly,and if the pilot light starts to get weak,and try to go out,then push back down,and hold 30 seconds more.After the pilot stays lit,turn the knob to furnace or low,or whatever the directions say.
Oct 19, 2009 | Heating & Cooling
I cant find the way on how to light uo the friar.
If you have a pitco 35 fryer, all you need to do is have gas connected and turned on, rotate the know on the gas valve to the pilot position, depress the knob, while holding the knob down light the pilot, normally located in between the burner tubes in the middle of the front of the fryer, hold the knob for 60 seconds, when you release the pilot should remain on. If it does rotate the pilot know to the "on" position, from this point the thermostat should control the fryer. If your pilot does not stat lit, press the red button on the hi-limit to reset it, it could be tripped and this would cause the pilot to not hold. Hope this is helpful.
Mar 18, 2009 | Pitco Frialator 35CD Deep Fryer
Honeywell propane relay won't start
For the pilot you have to hold the red button down for about a minute or two while it is lit, then turning it to on. If you tried this and it still wont stay lit then you can try replacing the thermocouple. For the relay the best way to tell is take voltage reading to see if the coil is getting voltage across it.relays are usually inexpensive,and easy to install.Just be sure to turn the power off befor touching the wires,and mark them so you know which wire goes to what terminal.
Mar 07, 2009 | Frymaster Dean 2424G Deep Fryer
Lighting the fryer
If this is a milivolt unit, meaning no solid-state or computer/digital controlled. You would need to turn your gas valve to the pilot position, then press in and hold until you can light the pilot using a lighter (this may take several minutes, to bleed the air from gas supply) once there is a pilot flame present, you will need to hold the valve button in for about 45 seconds to heat the thermalpile. Once pilot is lit, thene turn to on position and proceeed to turning thermostate to set temp.
Scoota
Jan 25, 2009 | Pitco Frialator SG14 Deep Fryer
Anets Fryer- Gas- Floor Model- Legs- 35-40 lb Logo
26 people viewed this question
Top Anets Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you an Anets Kitchen Appliances - Other Expert? Answer questions, earn points and help others
