Question about Samsung LN-S4051D 40 in. LCD Television
Power problem tv turns on and off continuiously
Swannn dvr 16 ch. model # N3960...plugged it in and says loading on tv screen but then turns off back to loading screnn then flashes off continuiously....thats with HDMI PLUGGED INTO IT
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Nov 03, 2016 | Televison & Video
TV model # 42631 has a continuious green light blinking rapidly
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Electro help
Jan 16, 2014 | Mitsubishi Replacement Oem V33 Pwb-dm...
On reboot how do i get to safe mode? I have a virus and things are being blocked from use !
As computer powers up tap the F8 key continuiously. That will bring up the options screen.
Sep 25, 2009 | Dell PowerEdge 1300 Server
Tv will not turn on
Get a power extension cord to connect your TV power to another (zone)room by using a different outlet and see if that is still does it.
Remember when you unplug the TV,you want to give it 15-20 seconds first .
If it still have the same issue,i hope you have the warranty,you are going to need it for repair.
solutiondoct
Nov 11, 2008 | Hisense Televison & Video
TV will not come on either with power switch or remote control
GOOD DAY, HOUSEFLY21JO;
YOU DID NOT ASK A QUESTION OR PROVIDE A MODEL OR BRAND. ARE YOU JUST MAKING A STATEMENT OR DO YOU WANT SOME HELP? I WILL HELP I JUST NEED SOME MORE INFO.
THANKS, BIG IRISH.
Aug 07, 2008 | Televison & Video
Lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Jun 02, 2008 | Televison & Video
Monitor will not display
Hello, tech support online at Sony was able to help me correct the problems.
Mar 08, 2008 | Princeton Digital VL1812 18.1" Flat Panel...
Mitsubishi 65 inch rear projection diamond
its the circut board that leads into tv from power cord , i had bought mitsubishi65819 black diamond gray 65inch for $54 ,is under the warranty the board cost $350 , labor $200 but this depends on where u live ,either way it was a steal for me ,but yea i had same problem when u turn tv on it shuts down like not even 2seconds i had tech come out and he had to take the board to get it repaired ,its not available he said but its repairable , was a sears tech so sears can repair it
Oct 29, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Samsung LN-S4051D 40 in. LCD Television Logo
16 people viewed this question
Henry  Thomas
Henry Thomas
