Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
I am connected to network but have limited or no connectivity
I had to start computer back to factory specs. Reinstalled DI-624 drivers and wireless card. Message says I am connected to network but have limited or no connectivity. I've rebooted, reinstalled, etc. What do I do now?
    Scholar:
  • 92 Answers
Wireless Troubleshooting Checklist 1. Unplug power from Router and Modem for 3 mins. 2. Restart computer. 3. Make sure your wireless device is active: a. Verify that your wireless device is turned on. Some laptops have a physical hardware switch located on the case. Make sure this is in the ‘On’ position. Other laptops use a Function Key combination (e.g. Dell uses Fn+F2, IBM uses Fn+F5)
b. Open Network Connections (from the System Tray or from the Control Panel). Verify that your wireless Connection is Enabled. If not, right-click on your wireless connection and select ‘Enable.’
4. Renew your connection. Changes elsewhere on the network can sometimes knock out your connection. To reconnect quickly, click Start, Run in XP (or press the Windows key in Vista), type ipconfig /renew, and press Enter. 5. Check for interference. Have you installed any new wireless devices (speakers, baby monitors, ect)? If so unplug them. Make sure your wireless network has a unique name (ssid). 5. If other wireless devices can connect to your router and only your computer can't. a. Try deleting your wireless profile. If you are using the built in wireless for windows go to Control Panel> Network Connections right click on Wireless Network Connection and select View Avaliable Networks. On the left hand side under Related Tasks click on "Change the order of preferred networks" select your network name and click remove. Now try reconnecting to it. Be sure to type in the correct security key. b. Disable your software firewall. 6. If you can connect to the router but not the internet. a. Click Start > Run type CMD into the box and click OK to open a command prompt.
At the prompt type netsh winsock reset catalog
This will Reset WINSOCK entries to installation defaults
When the first one is done tyoe this netsh int ip reset reset.log
This will Reset TCP/IP stack to installation defaults
Reboot the machine. b. Change the name of your wireless network (SSID) c. Change the wireless security key and or wireless security type. Some devices are not compatible with the WPA encription. be sure to use a HEX password Hex is 0-9 and A thru F only. The Hex key
must be exactly 10 characters long for WEP64, or 26 characters long
for WEP128. If you're using 5 characters or 13 characters, it's
really ASCII, not HEX. Please don't forget to rate this solution.
Posted on Jun 14, 2009
How many devices can connect via wireless to D-Link DI-624?
It can connect as much as 10 computers or wireless networking devices. As long as your base connection is good you can connect as many devices as you can. Because the wireless technology is unlimited and limitless.
Jun 19, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
How do I set a pass word on my DI-624 router
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Sep 14, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have a D-Link AirPlus DI-524 Wireless Router. I have no problem connecting the computers in my home that have windows XP installed. We have replaced two of the computers in the house with laptops that...
I have had exactly this problem and after MUCH work downloading new drivers for the Vista Pcs and updating the operating system in the DI-524 found that the 524 does not operate well with Vista. A new DI-624 integrated well with Vista, and installed with no problems. Good luck!
Feb 22, 2009 | D-Link AirPlus DI-524 Wireless Router
D-Link DI-624 AirPlus Xtreme G 2.4GHz Wireless router not connecting using the wireless point on it
The DHCP on your router isn't working properly. You should perform a hard reset on the router by finding the reset button on it. Take a pen or other small pointy object find find a tiny hole on the router. Press and hold this for 20-30 seconds. This will reset to factory settings and the password to the router will also be reset to its normal default.
Reconfigure the router as if you had just bought it new and it should work properly this time
This is from a DI-624 Router, and should be very similar to yours:
Oct 16, 2017 | D-Link AirPlus Xtreme G DI-624S Wireless...
DI-624 problem with wireless network
Buy the N router! That is the only solution. My signal weakened and went from the whole home to less than two feet if that at times. I bought the N router and it worked just like the G one did when I first bought it. Ya think somebodies got the limited life span worked out?
Jul 10, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
X-Box 360 Wireless Connection
you just check the network. properties try then un plug the cable of the wireless connection, upter a 5 minutes plug it on
Jun 19, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Internet Connection
try a cross cable between di-624 and westell dsl router.
Jan 12, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
392 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
