Aprilia service centers in philippines
Type of battery and type of starter
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
It is a cr2032 battery looks like a nickle size
Posted on Mar 24, 2014
2014 Aprilia SR 50 Motard will not turn over
Hi, Belinda before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Engine Run Switch is "FAULTY" or corroded.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
5. Bank angle sensor needs a reset or is faulty.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand, clutch, neutral safety switch.
10. Security alarm needs a reset.
11. Starter relay, solenoid, starter motor or circuit wiring faulty.
12. Starter armature or field coils have failed.
13. Main fuse or circuit breaker may be blown or faulty.
14. Faulty ignition relay.
15. The electric starter is working but starter clutch has failed.
16. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
my SR50 wont start
https://www.scootershack.co.uk/threads/aprilia-sr50-wont-start.18484
https://scootergrisen.dk/scooterhjemmeside/download/aprilia_sr_servicemanual.pdf
Aprilia SR 50 Motard 12 LBMC502 Parts Accessories Scooter Parts Racing...
APRILIA SR 50 2001 Manual
May 01, 2018 | 2014 Aprilia SR 50 Motard
2008 Aprilia SportCity 250 how to replace the starter relay
Hi, Timothy for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Aprilia, despair not, for a mere zero $0 you can download another one.
http://www.apriliaforum.com/forums/showthread.php?188264-sportcity-250-starter-clicks-won-t-crank
NEW STARTER BUTTON APRILIA SPORTCITY CUBE 125
Aprilia SportCity 250 ie Service Manual
Products Components
APRILIA SPORTCITY 250 2006 Manual
Dec 05, 2017 | 2008 Aprilia SportCity 250
Shiver has ECU plug error
Hi, Richard and the usual suspects are:
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Thread Fault Finding Shiver ECU Faults
Aprilia Shiver Urgent Service Problem
Aprillia Shiver SERVICE errors reset
Aprilia SL750 Shiver Workshop Service repair manual Download Manuals...
Apr 02, 2016 | 2009 Aprilia SL 750 Shiver
Where can I buy genuine leather strap of my fossil watch and at the same time repair its glass..Is there fossil service center here in Quezon city Philippines
There is!
Fossil Saved to your Map View on Map Website Directions Boutique Chain retailer known for vintage-inspired watches, leather goods & more, along with modern designs. Address: North Avenue Corner Edsa, Quezon City, Philippines Phone:+63 2 924 2763
Fossil Philippines Service Center - AllServiceCenters.Com
allservicecenters.com/FOSSIL/Fossil-Philippines-Service-Center-Custome... Displaying entire information about Fossil Philippines service center and customer ... Arcade, Ayala Center Ayala Avenue, Makati City, Metro Manila, Philippines. Missing: quezon
Warranty & Repairs - Fossil
https://www.fossil.com/us/en/customer-care/warranty-and-repairs.html Rose Tone Watches · Stainless Steel Watches ... City & Courier Bags .... India; Indonesia; Macau; New Zealand; Philippines; Singapore; South Korea; Taiwan ... Missing: quezon
Jan 31, 2016 | Fossil Watches
Not starting off starter but goes with a push
Hi, Malcom Smith famous dirt bike rider extraordinaire and the usual suspects are:
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a "LOAD" test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
APRILIA RS 125
Aprilia rs 125 trouble starting arghhh
RS50 wont start off motor but will easy when bumped
https://www.manualslib.com/manual/363586/Aprilia-Rs-125-Tuono-2003.html
Products at Aprilia Genuine Parts Aprilia Parts Aprilia Spare Parts...
APRILIA RS 125 2006 Manual
Mar 18, 2017 | 2003 Aprilia RS 125
Service center philippines
Good Morning Friend,
I understand you are looking for a service center in the Philippines. I suggest contacting the manufacturer, in the Philippines. They should be able to best assist you in finding a service center. Hope this is helpful.
-Best regards-
WP
Jun 21, 2014 | Frigidaire Washing Machines
I'm here at philippines, my i ask where i can buy a battery pack of acer aspire 4720. thanks
Here go to this link it has the link for acer service center in philippines. Try asking for battery pack.
http://www.acer.com.ph/ac/en/PH/content/support
Hope it helps.
May 12, 2011 | Acer Computers & Internet
2006 Aprilia SXV 5.5 will not start
Hi, Mlimnatis before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
08 SXV 5 5 Won Start
sxv550 starting issues
http://slorider.com/Aprilia/manuals/SXV_RXV_450_550_Engine_English_2006-06.pdf
http://slorider.com/Aprilia/manuals/Spare_Parts_Accessories_Catalog_2007-02.pdf
http://slorider.com/Aprilia/manuals/SXV%20RXV%20450-550%20English%202006.pdf
Aug 02, 2017 | 2006 Aprilia SXV 5.5
Authorized Service center in the Philippines
My camera has no power even if i put new batteries.
Oct 23, 2009 | Polaroid I1037 Digital Camera
Computers & Internet Logo
David Payne
David Payne
