Question about Karcher PSI Electric Pressure Washer
Power Washer lost pressure and is leaking through Pistol
I purchased my second Karchner Power Washer after my first lost pressure. The new one was used only once last Summer and is doing the same: Lost Pressure and is leaking through the Pistol, no detergent or anything was used ever in both of them.
What is the Problem and How to solve this Problem??
SOURCE: B302 - unable to start detergent flowing - How should it work?
It will only pick up detergent if you use a low pressure detergent nozzle - or no nozzle at all. It also takes a while for the detergent to get to the nozzle.
Posted on Nov 19, 2007
  • 313 Answers
SOURCE: hooking up detergent to pressure washer
detergent can only be **** from the container only on low pressure.
Posted on Jul 08, 2008
SOURCE: karcher k7.80 pressure washr
I have a Karcher K 3.86 M electric PW with a similar problem: water leaks from the pump near the outlet and the pressure surges on and off continuously at intervals of 1-2 seconds. The leak appears to be coming from a very thin crack in the plastic pump head in what I think is the "unloader" valve portion. I read elsewhere that if you leave water in these PW's and it freezes it will crack, causing leaks. I don't know how you can empty all the water out so I think we must store these PW's in areas that won't freeze in winter.
Posted on Jul 16, 2008
stug_57u
  • 99 Answers
SOURCE: No pressure in the pressure washer
Leaving the hose on shouldn't cause a problem so don't panic. It sounds like you could just have a dirty nozzle. Try sticking a pin or something in the end of the nozzle (machine not running) and giving it a clear out. also if it is a two peice gun, split it and tap the squirting part on something clean like a workbench to clear any debris that might have got in there.
Posted on Nov 01, 2008
  • 92 Answers
SOURCE: Karcher pressure washer won't start
Dear ralph_birtwi,
Most pressure washers when their gun is released, the machine stops automaticaly. This is done ny means of a control valve. When the gun is closed...pressure is built and the control valve moves and switches a micro switch off. In your case the micro switch is still closed in off position. Now this happens if a machine is left and stored with pressure in it., This control valve could get jammed and leaving the micro switch in off position. It could also stay in off position by sticking, due to incorrect chemical.
So the control valve or even called spill valve, must be renewed.
Sometimes a little lubrication with the right type of silicon grease will get the control valve working again. This job is sometimes delicate and better done by a qualified technician.
Regards,
fulltech.
Posted on Apr 12, 2009
Leaking water
You will need a new gun but if the hose is attached you will need that as well. As far as I know these small electric washers have the hoses and guns as one unit and repair is not an option.
Mar 12, 2014 | Black & Decker Garden
I can't get the pressure washer to start up. The water is coming out of the hose, but there is no water pressure
If the washer is the kind that shuts off completely when the pistol grip is released, the problem is likely the little pressure sensor located near the output fitting (the threaded part to which the hose connects). The sensor is a little plunger held down against an opening in the side of the pipe by a spring when there is low or no pressure in the output pipe, as when the trigger is pulled and the pressurized water in the hose is released by pulling the trigger. That completes the electrical circuit and the washer is on and continues pumping water. When the trigger is released, water in the hose and output pipe jams up super high pressure, forcing tjhe little plunger out against the spring, and the electrical circuit is broken. If you take the case apart, you will see wires coming from that area. The fix (if this is the problem) is to free up the little plunger.
Dec 05, 2012 | Coleman Powermate DuraBuilt 1400 PSI...
My K5.20M power washer won't start. Am looking
Make sure your extension cord is able to provide 13 amps or greater of current. The longer the extension cord the more current it requires to supply the 13 amps to your power washer. If your unit has a long extension cord it could pull more than the typical 15 amps used for a household circuit breaker. If you do not have an adequate circuit breaker it will continue to trip. Now that you have the correct power supply you will notice the GFI Test and Reset buttons by the power washer plug. Plug the power washer into the power receptacle which has live power. Make sure the power washer is off and then push the reset button located on the power washer plug until you hear a click. The GFI should be reset and you can now turn on your power washer.
Jul 26, 2010 | Karcher Garden
Pump leaking from base
I have the same Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A manufacturing defect.. A New Manifold Complete Replacement is about $61.03, about the half the price what I paid for this pressure washer at Walmart... :( If under 1 year old, and you can find a receipt to prove it,Karcher will replace the whole Pressure washer under warranty.
Jul 06, 2010 | Karcher K2.26 Electric Power Washer
Air pistol c02 replacement
Well that takes me back! I have an old Daisy 1200 -- essentially the same pistol in a different brand.
My Daisy has a hand-turn screw to hold the CO2 cartridge in place, and you have to tighten it quickly until the leaking stops. It does this by pressing the cartridge up against a nylon washer to form a seal (and of course pushing it into the piercing pin to get the CO2 out!)
With age, I'd expect that nylon washer to get stiff or crack, making it harder to form a good seal. You don't need an exact replacement part, but if that's happened to yours then you will need to replace it with something more-or-less the same size as the original.
May 30, 2010 | Crosman 1377 177 Single Shot Air Pistol
Pressure washer lost pressure in the middle of a job
The pressure valve has stuck in the high pressure position. This prevents anymore inflow and hence no further water will be pumped.
Rebuild the valve... There are O Rings to replace and clean the bore with croocus cloth. Lube the O rings with plumber's grease... good as new! 15 minute job. Get EXACT sized O rings for the unit.
May 16, 2010 | Honda Pressure Washer PSI 3000
The high pressure lance has sprung a leak can i purchase a new one
If we're talking about a pressure washer, then yes, you can purchase a new lance. Companies usually sell replacement parts, and there are also after-market parts available. You didn't state the brand or model # of the pressure washer, and depending on the brand and model, you may be able to repair the leak. It may be a matter of a worn O ring. If you purchased the washer locally, go back to the store and ask for a repair kit or O ring (s). They will also have lances as well.
Was this helpful?
Aug 08, 2009 | PowerBase Car Audio & Video
Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Jun 03, 2009 | Karcher G 2600 VH Gas Pressure Washer
Karcher pistol gun has broken
i do not think there is a pressure release valve , sounds like the plastic inside the pistol has become brittle and has failed under pressure , you dont say how old the pistols are ? and if you run strong detergents through them .
May 26, 2009 | Karcher PSI Electric Pressure Washer
Karcher PSI Electric Pressure Washer Logo
332 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
