Question about Golds Gym 3-in-1 Jump Rope
How do i fix the length of the jump rope
The beaded jump rope from Walmart is too long for me
I just bought the Weider Beaded Jump Rope and it is too long for me is there a way to shorten it without ruining it?
if you're careful and crafty you can try to take the beads off the rope and use a scissor to cut the rope to your ideal height, If the jump rope isn't constructed to be disassembled or you don't wanna take the risk, try tying a knot on both end of the handles to shorten the rope. btw you probably know this already, but when trying to determine the length of a jump rope you should stand on the center of the rope and make sure each end of the handle reaches your armpit or at least your chest
Jan 16, 2013 | Weider Jump Rope, Beaded, 1 rope
Tip
Seal bead on flat tire to refill with air
Most lawn tractor tires are now tubeless and when they go flat the seal of the tire bead and rim are lost. It is very difficult to restore the seal in order to refill the tire and determine what caused the flat. Here is my tip to seal the bead, & fill the tire, without having to remove the wheel from the tractor. Wrap a length of heavy rope, or a fabric hold down strap centered around the outer circumference of the tire tread and secure with minimum slack. Place a bar, long box wrench etc. between the rope and tire and turn in whatever direction you choose keeping the ends of bar above the rope. As you turn the rope will begin to twist and cinch and collapse the center of the tire causing the bead to evenly seal against the rim.
Add air until you feel pressure building then back off cinch as you fill until you are sure bead will hold on its own. This works great on wheel barrow tires as well.
Good Luck
on Apr 02, 2015 | Garden
Should I buy a beaded rope?
A beaded rope is one made out of nylon with plastic beads along it. It can be used on any surface including concrete and it won't destroy the rope. I just started jump roping recently and got one of these because it doesn't get tangled. Also I can hear the beads hitting the ground which helps me keep my rhythm.
Jan 03, 2013 | Exercise & Fitness
Are there different names for jump roping?
Jump Roping can also be called skipping, rope skipping, or rope jumping. Skipping rope is generally the British way to say it, while Americans say Jumping rope.
Are there different types of jump ropes? What is the difference between them?
There are speed ropes, cloth ropes, and beaded ropes.
speed are a cost effective and easy to adjust style of jump rope, Beaded ropes are the most durable jump rope style suitable for any environment but they are the best rope for outdoor and colder weather use. Cloth en cloth ropes are the finest quality ropes on the market.
How do I know if the jump rope is long enough for me?
In order to determine the right length, stand on the center of the rope and reach the handles towards your armpits. If the rope is a good fit they should just reach your armpits when stretched from the floor.
Aug 26, 2012 | Cobra Exercise & Fitness
Can't get a bead on tire
Hey mate,
The problem in you are not getting enough air flow past the valve its restricting all the flow into the tyre!!!
With your valve stem, remove the valve with a valve removal tool, then you will get no restriction of air flow also use a hand air gun instead of tyre inflator this should pop the bead on then it will go down again, reinstall the valve (you can put some spit/saliva on the valve for a good seal) then use a tyre inflator and pump it up to the desired pressure...
Regards
Brad:)
Sep 22, 2009 | SK Garden
How do you adjust the valeo speed jump rope for your height?
It's simple, really.
At each end of the handles, you'll see a black cap. You can use a flathead screwdriver to go right in the crack of it, and pop it out. You then take the black rope, pull it out, and move down the silver piece until it fits your height. If you're like me, you'll need to cut some of the rope so it will fit in the handle. After you have adjusted it to the right height, snap the black caps back in.
Feb 19, 2009 | Valeo Speed Jump Rope 1 Pk
Golds Gym 3-in-1 Jump Rope Logo
75 people viewed this question
Top Golds Gym Exercise & Fitness Experts
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Propulsive
Level 1 Expert
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
