Question about Android Apps
Gb220at v10a I can't send and delete messages
I can't send messages keep getting the message not enough memory to support operation delete some data?
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Aug 02, 2012 | Nokia E5 Cell Phone
I canT recieve and send a messaage because my phone says that ' memory full, delete some data first" and i didn"t know how to delete that said data.
you need to delete some of your texts also go to your setting and click auto delete on it will delete the last one everytime you fill up your box so you will never run out of space.
Feb 06, 2011 | Nokia N70 Cellular Phone
Receiving, but not sending text messages
just go to message setting and open sending option and check the no. of text message centre whether it is there or not
Jun 07, 2010 | Sony Ericsson w580i Cellular Phone
How do i delete pending messages, I cant send pictures on the lg Lotus.
Do you mean you want to delete Picture Mail messages?
If you can't send a picture message, the lg lotus will save it and retry sending it at a later time.
If you want to delete those messages go to:
Main Menu > Messages > Picture Mail> Pending messages> Select message> Options> Delete
Picture mail requires a data plan also. :)
Hope that helps!
Oct 24, 2009 | LG Lotus Cell Phone
I can receve texts but can't send
its usually because your phone crashed when you were sending a text. If you delete the whole of your inbox, there should be one message that says delete failed, you need to cancel sending the message, then move it to drafts you might have to turn your phone off in between this process, then try to delete it from your drafts, it should say delete failed, so turn your phone off and on again, then you should be able to delete it out of your drafts and you then shoulde be able to send messages
Jun 05, 2009 | Sony Ericsson W890i Cellular Phone
Want to delete messages
first go to messages and then click the option and delete.. if u want to send message just only click messages and then click to write message den type your message if finished click the no. of person den click send..
Apr 17, 2009 | LG KF310 Cellular Phone
Cannot remove number in the sent IM menu of the LG Rumour
Click on messaging icon from main menu.
Click send message.
Instead of clicking text message click on pic/video message.
then you have 4 options TO: CONTACTS , TO Mobile#, To Email, And finally To Recent lict. Click on recent list and checkmark all the numbers you want deleted then click options bottom right corner then click delete.....
All finished hope this helps.
Jan 05, 2009 | LG RUMOR Cellular Phone
Cannot send a text message
Message sending failed.
Solution : Delete all message in Sent Item one by one. Problem solved
Dec 18, 2008 | Cell Phones
Reason of this Problem:
Actually it happens due to mem full in Sent Items with Pending Status.
Solution:
Just delete one message from Sent Items.
Better if you delete all messages from your Sent Items, as you will face again this problem if again Sent Items fulls with messages having status Pending.
Regards,
Shakir Idrees
Mar 23, 2008 | Nokia 1112 Cellular Phone
Android Apps Logo
Top Apps Experts
Brett Duxbury
Brett Duxbury
Are you an App Expert? Answer questions, earn points and help others
