Question about Black & Decker 3.8 AMP 22-Inch Electric Dual Action Hedge Trimmer #HT022
Keeps shutting off
When running it shuts down
MY 2006 SUZUKI AERIO KEEPS SHUTTING DOWN AFTER RUNNING FOR ABOUT 5MINS
Bad gas cap, not allowing air to enter is one possibility. Other is bad ignition coil/module. Check for spark immediately at failure.
Jun 21, 2014 | 2006 Suzuki Aerio SX
My desktop keeps on shutting down THERMAL VENT OVERHEATING
Try to remove the dust buildup in the back of the tower. If necessary unscrew it and vacuum clean.
Apr 13, 2013 | Dell OptiPlex GX620 PC Desktop
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
Natural gas generator shuts down after about 5 minutes and won't keep running.
How big a unit? Model number? Alarm codes? If it runs for 5 mins check the obvious, coolant level, oil pressure and sensor,
Nov 07, 2012 | Caterpillar Electrical Supplies
Computer keeps shuting down
Shuts down when? Right after you boot it up? Or does it run a while then shut down?
If it shuts down after it has run for a while then the computer is probably running hot. Either the CPU Fan is not working or the Thermal Paste has dried up or is too thin to keep the CPU Cool. To prove it is running hot, let the computer sit for a while then boot it up. Once it boots up use it until it shuts down and immediately try to boot it up. If it does not boot up that means it's running hot. But if you let it cool off then try booting up you will be successful.
Mar 27, 2012 | Compaq Computers & Internet
Shuts down going down the road shuts off completely
vehicle shuts down while driving down road and does not start backup for at least 20 minutes, could be a bad crank sensor. if bad it will start and run fine, but it will keep shutting down until fixed.
May 16, 2010 | 1997 Nissan Pathfinder
Fan keeps on running, never shuts off
Check for the thermal grease below the heat sink, it may be exhausted..
Dec 09, 2008 | Computers & Internet
Black & Decker 3.8 AMP 22-Inch Electric Dual Action Hedge Trimmer #HT022 Logo
46 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
