Question about Ryobi Garden
My Ryobi RY08548 starts OK, but when I try to run at speed, it stalls.
  • 1,041 Answers
First, you will need to check the fuel lines for cracks & breaks.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
(NOTE: If the carburetor parts are more than four years old, and depending on the use, you will need a new carb. kit if the cleaning doesn't work.)
If you need further assistance, just let me know.
Jim
Posted on Jun 18, 2009
  • Jim Parker
    Jim Parker Jun 21, 2009
    Did this solution solve the problem?
    Jim
Ryobi leaf blower stalls when i give it gas idels fine but when i pull the triger it stalls
remove the muffler and run it if ok with the muffler off open it up and clean the screen inside
Jun 14, 2012 | Ryobi Garden
My Ryobi C430 stalls when I try to give it gas. It idles fine though.
remove the muffler and try it if ok with out it open the muffler and clean off the internal screen
Apr 04, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi CS30 - Stalls out?
Dirt or varnish in fuel filter or carburator. Change filter if there is one.
Flush out the carb with a varnish remover.
Open high speed needle valve 1/8 turn farther, then turn in while running until it just smooths out.
Jun 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi lawn trimmer keeps stalling out. I have
If it is a relatively new unit it should have the carburetor adjusted after the first few hours of use. If it stalls upon accelleration the low speed adjustment on the carb needs to be opened a little bit. If it runs a few minutes and then stalls it could be the high speed jet needs to be opened or the fuel filter is clogged.
Sep 16, 2009 | Ryobi Garden
Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Jul 05, 2009 | Garden
Lenght and position for Ryobi RY08548 Blower fuel line in gastank
take off the fuel filter and see if that works . if it runs then it needs a new fuel filter. keep me posted
Apr 11, 2009 | Garden
Garden Logo
378 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
