Question about Yaesu FT-77 Original Owners Manual
Transmition stops after 4/6 min
Cuts off transmitting after 4 to 6 min takes about 40min to be able to tx again
    Sergeant:
  • 435 Answers
What is your SWR, sounds like you need to tune the antenna, the radio is only doign what its supposed to do if the standing wave ratio (SWR) is too great
Posted on Feb 03, 2015
Binatone terrain 550
can you hear it though, sometimes these lights stop working
Aug 11, 2014 | Radio Communications
Why does my kenwood TH-K2 fm transceiver will not transmit
Users Manual (download if you don't have it)
TX I
NHIBIT
You can inhibit the transmission to prevent unauthorized
individuals from transmitting, or to eliminate accidental
transmissions while carrying the transceiver.
1 Press [MENU].
2 Turn the Tuning control to select Menu No. 25 (TXI).
3 Press [MENU].
4 Turn the Tuning control to select "ON".
5 Press [MENU] to store the setting or [PTT] to cancel.
"TX INH" appears and an error beep sounds if the
transceiver tries to transmit while TX Inhibit is ON
May 11, 2014 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
My hr2600 shows error 3 when it is keyed up and does not transmit
0 = Transmitter Timeout timer has timed-out
1 = Transmit Frequency is lower than TX Lockout Lower Limit
2 = Transmit Frequency is greater than TX Lockout Higher Limit
3 = Phase-locked-loop (PLL) won't lock at this transmit frequency
4 = PLL is intermittently coming out of lock during transmit
*If your radio displays error 3 or 4, don't keep trying to transmit on this frequency. The cause of the problem could be low power supply voltage to the radio or the radio's VCO loop needs adjustment. Refer to a qualified technician for service. Contact the installer of the chip first. If, however, you installed the chip yourself, contact a qualified technician for service.
Sep 24, 2013 | Magnum DeltaForce CB Radio
My connex cx3300hp wont transmit
You need external watt meter& SWR meter..Change antenna..Is the radio meter keying 3/4 way up to 4 watts?(if not then its not Tx'ng)It could be 10.240 mhz crystal or IF pots(need Frequency counter) Or take it to professional Cb repairmen...
Mar 12, 2013 | Radio Communications
I removed my Roger Beep from my Eagle Sidewinder 400, It still receives but will not transmit. What do I have to connect back up for it to start transmitting again? I'd be Thanking you for any help.....
If the radio is not going into TX, then you have not connected the TX line back up,
If there is no audio when you TX you have left the audio wire off.
The radio usually needs 4 wires.
TX (Puts radio into TX)
Audio (this carries the audio from the mic into the modulator)
Screen (ground cable (earth))
RX (not as common these days)
May 18, 2010 | Radio Communications
Please send me Canon Ir all model Error code. How can solve it?
Error codes for iR2016i,2020i for other machines codes you need to get the specific manual, these manuals can be downloaded from Ebay, look for user ID ultimate_sacrifice A seller on Ebay.
No. Tx/Rx Description
##0100 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0101 [Tx/Rx] the modem speed does not match that of the other party.
##0102 [Tx] at time of transmission, fall-back cannot be used.
##0103 [Rx] at time of reception, EOL cannot be detected for 5 sec (15 sec if CBT).
##0104 [Tx] at time of transmission, RTN or PIN is received.
##0106 [Rx] at time of reception, the procedural signal is received for 6 sec while in wait for the
signal.
##0107 [Rx] at time of reception, the transmitting party cannot use fall-back.
##0109 [Tx] at time of transmission, a signal other than DIS, DTC, FTT, CFR, or CRP is
received, and the procedural signal has been sent more than specified.
##0111 [Tx/Rx] memory error has occurred.
##0114 [Rx] at time of reception, RTN is transmitted.
##0200 [Rx] at time of reception, no image carrier is detected for 5 sec.
##0201 [Tx/Rx] DCN is received outside the normal parity procedure.
##0220 [Tx/Rx] system error (main program out of control) has occurred.
##0232 [Tx] encoding error has occurred.
##0237 [Rx] decoding error has occurred.
##0261 [Tx/Rx] system error has occurred.
##0280 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0281 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0282 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0283 [Tx] at time of transmission, the procedural signal has been transmitted more than
specified.
##0284 [Tx] at time of transmission, DCN is received after transmission of TCF.
##0285 [Tx] at time of transmission, DCN is received after transmission of EOP.
##0286 [Tx] at time of transmission, DCN is received after transmission of EOM.
##0287 [Tx] at time of transmission DCN is received after transmission of MPS.
##0288 [Tx] after transmission of EOP, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0289 [Tx] after transmission of EOM, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0290 [Tx] after transmission of MPS, a signal other than PIN, PIP, MCF, RTP, or RTN has
been received.
##0670 [Tx] at time of V.8 late start, the V.8 ability of DIS front the receiving party is expected
to be detected, and the CI signal is expected to be transmitted in response; however,
the procedure fails to advance, and the line is released because of T1 time-out.
##0671 [Rx] at time of V.8 arrival, procedure fails to move to phase 2 after detection of CM
signal from caller, causing T1 time-out and releasing line
##0672 [Tx] at time of V.34 transmission, a shift in procedure from phase 2 to phase 3 and
thereafter stops, causing the machine to release the line and suffer T1 timeout.
Dec 12, 2009 | Office Equipment & Supplies
Stops working when I try to transmit.
problem may be the button loose connection to the main board...we can fix these radios. cb shop temple, tx on yahoo search. The button is connected in so it controls both sections.
Aug 03, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Fax question
You want a TX (transmit) Report. You can have the report printed after each fax is transmitted, including the first page of the fax sent if desired. Follow these steps to turn on the report.
1. Press Menu button
2. Use (left or right) arrows to FAX SETTINGS, press Set button
3. Use arrows to REPORT SETTINGS, press Set button
4. Use arrows to TX REPORT (may be there already), press Set button
5. Use arrows to OUTPUT YES, press Set button
6. If screen says REPORT WITH TX IMAGE, press Set button
7. Use arrows to ON or OFF, as desired, press Set button
8. Press Stop/Reset to exit the menu
May 05, 2008 | Canon FAXPHONE L170 Plain Paper Laser
My galaxy 959 cb radio wil not put out any transmit
Based on your post of no transmit, a couple of possibilities:
1. defective microphone or cord or PTT switch (the red TX light does not come on when pressed);
2. TX light comes on but no output, defective finals and/or drivers. These are the transistors screwed to the chassis of the radio very near the antenna terminal;
3. defective regulator IC that provides the TX B+;
5. insufficient amperage from you power supply;
6. too high SWR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 16, 2008 | Radio Communications
One radio continually transmits
Hello
This could be the Ptt Switch , Midland is 3 Years warranty try to claim the warranty, this is a Factory fault.
Oct 25, 2007 | Midland LXT303-A 2-Way Radio
Yaesu FT-77 Original Owners Manual Logo
62 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
