Pseudocode to calculate tuition increase for five years
Question regarding aviation.?
Embry Riddle is one of the most expensive colleges you can attend for flight. There are many others such as University of Cincinnati and University of North Dakota that offer college programs in flight and aviation. Airlines do want college degrees so it's really a pretty good idea. I'd check out tuitions at other colleges that offer aviation.
Jan 04, 2017 | Aircrafts
Search a string of at least five numbers (for example, 65403) Identify all of the substrings that form numbers that are divisible by 3.
I guess a hint is that to see if a number is divisible by 3, you can add up the digits of the number and if the sum is divisible by 3, the number is divisible by 3. Another way of seeing if a number is divisible by 3 is to do an integer divide and then multiply back to see if you get what you started with. For example, 7 / 3 = 2. 2 * 3 = 6, thus 7 is not divisible by 3.
As for all the substrings, start at the 5th number and do substrings of length 1 to 5, Move to the next digit, do substrings of length 1 to 4. Move to the next digit, do substrings of length 1 to 3. Repeat until only 1 digit is left.
Good luck,
Paul
Apr 12, 2016 | Office Equipment & Supplies
Write a pseudocode declaration for a string array initialized with the following strings einstein newton
the nice thing about pseudocode is that there's many ways to do it
E.g 1;
String str = new Array["einstein',"newton"];
E.g 2;
myStringArray = new Array{'einstein','newton'}
BOTH of the above are correct, because they are pseudocode
Oct 19, 2014 | Computers & Internet
How do I calculate percentage of increase
3=100%
26=A (the A is the percentage of the this year)
so we make 26*100=3*A
2600=3A
A=2600/3=866.67 (is the percentage of the this year)
and to know the percentage increase (we remove the percentage of the last year (100%) from the percentage of the this year 866.67%
so we get 866.67-100=766.67
so your percentage increase is 766.67%
i wish it helps
Jul 04, 2014 | Computers & Internet
What is the formula to find the percent between two numbers. example: nuts cost .233 last year and this year nuts increased to .332 what is the percentage increase.
Divide .332 by .233, multiply by 100, then subtract 100.
Alternatively, since the increase in price was .099, divide .099 by .233 then multiply by 100.
Aug 10, 2011 | Texas Instruments TI-84 Plus Calculator
I would like some help in solving some TVM problems using the BA II Plus calculator. i.e. How to solve: I invested a lump sum of $2400 in an investment that returns 6% annually. How much will the...
2nd [CLR TVM] (clear TVM registers)
2 4 0 0 +/- PV ($2400 initial investment, negative because you're paying it out)
6 I/Y (6% annual interest)
1 N (one year)
CPT FV (compute future value, see 2544.00, the value after one year)
5 N (five years)
CPT FV (see 3211.74, the value after five years)
1 0 N (ten years)
CPT FV (see 4298.03, the value after ten years)
Feb 19, 2011 | Texas Instruments BA II PLUS Financial...
How to convert cbm into sq meter
Now cubic meter calculator can be defined as a simple device which is used to convert a given value in meters to it's corresponding cubic meter form. Other than this we can always add the formulaes of the structures to get the volume of the structure by simply entering it's side length or height etc..
Let us consider simple examples :
Suppose that we have to convert 5 meters to its cube. The only thing we would do is that we would enter this value of 5 in the calculator and calculator with do the calculation as mimetex.cgi?%5cdisplaystyle%7b%7b5%7d%7d%5e%7b%7b3%7d%7d and will show the result to you as 125 mimetex.cgi?%5cdisplaystyle%7b%7bm%7d%7d%5e%7b%7b3%7d%7d .
Now if we have added formulaes to this calculator , like for calculating the volume of cube,cylinder and cone (say). Then we can use this calculator in three different cases.
Visit anthony's tuition class. Specialist in H2 Physics Tuition and H2 Maths Tuition.
Feb 10, 2011 | Office Equipment & Supplies
How do you set decimal places?
To halt the calculator and reset the keyboard, follow the procedure below:
  1. Press and hold the [C] key.
  2. Press and hold the third key from the left on the top row.
  3. Release both keys at the same time.
  4. The calculator will now display "0.00" (if the number of decimal places is set to two.)
To completely reset the calculator and erase all user memory, follow the procedure below:
  2. Press and hold the first key from the left (the N key) and the first key from the right (the sigma +) on the top row. Release all three keys at the same time.
  3. You should see "ALL CLr" on the display.
  4. Pressing the [C] key will clear the message.
  5. The calculator will display "0.00."
Feb 09, 2011 | HP 20s Calculator
I need open gl source code to make a point move along the circumference of the circle.
Hi
 I'm studying Physics, not CS, but I've had a few brushes with OpenGL.
 I'll use a Basic-like pseudocode syntax since I don't know what language you're using, and basic is very easy to read:
'Constants - Radius is radius of the circle
Const PI = 3.14159, Radius = 10
'Current angle, and angular velocity (dTheta / dt)
Dim Shared Theta as Single, Omega as Single
'Frame is called when you want to draw a new frame
Sub Frame(dt as Single)
  'dt is number of seconds passed since last frame (typically less than one, since you want several frames per second)
 'Initialize the frame (clear buffers, set up projection, etc)
 InitFrame
 'Increase angle
 Theta = Theta + (Omega * dt)
 'Calculate co-ordinates of point
 X = Radius * Cos(Theta)
 Y = Radius * Sin(Theta)
 glBegin(GL_POINTS)
  'Set the colour of the point
  glColor(<r>, <g>, <b>, <a>)
  'Draw the point
  glVertex2f(X, Y)
 glEnd()
 'Display the frame
 RenderFrame
End Sub
May 16, 2009 | Advanced Graphics Programming Using OpenGL...
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
