Question about Myron & Davis ADM170GY Car DVD Player
Cannot get DVD to eject?
Continues to say loading and will not eject dvd
How to eject dvd from tv set
If the loading belt is broken the CD inside will not eject. If the loading motor is defective, the CD mechanism won't eject. Anyway, the CD loading mechanism is defective. http://electronicshelponline.blogspot.com/
Oct 10, 2014 | Televison & Video
VCR EJECT FAILURE
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) and try loading and unloading a tape. Try to find the motor and belt which operates the loading mechanism. When it "catches" as you say, try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the tape is why you may not have this problem during the load sequence.
Jan 28, 2008 | Goldstar GBV241 DVD Player/VCR
Dvd player says loading and won't play dvd
Disconnect the power,push the eject button and connect the power while pushing the eject button.
Dec 01, 2009 | Televison & Video
We had no control of the DVD that we watched last night. No pause, fast forward, etc. Tonight, trying to watch another DVD and the one from last night continues to be playing and will not eject. Neith
Sometimes when you unplug the set ffrom the wall power or a while 1-2 minutes, and then plug it back in the problem will resolve itself. The DVD may eject. If it does, check it for damage, warping or dirt. If this does not fix it- you probably should take it to a repair center.
May 27, 2009 | Televison & Video
Sharp rw 260 : we are unable to eject dvd
Got help from yahoo answers little hole by dvd drawer inserted needle and hey presto working ok again. yipee
May 01, 2009 | Sharp Televison & Video
DVD/CD will not load and ejects
junk it and buy a better player...cheap dvd players fail quickly..
Feb 25, 2008 | Durabrand DVD-1002 DVD Player
DVD caught inside machine
When a DVD won't eject, the most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the DVD. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) try to find the motor and belt which operates the DVD loading & eject mechanism. Try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the DVD is why you may not have this problem during a load sequence.
Let me know what you find and we'll go from there.
Good luck,
- Jim
Feb 15, 2008 | Philips DVDR985 DVD Recorder
DVD is stuck
When a DVD won't eject, the most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the DVD. This can be fixed by either using a re-grip solution1.gif on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) try to find the motor and belt which operates the DVD loading & eject mechanism. Try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the DVD is why you may not have this problem during a load sequence.
Good luck,
- Jim
Jan 28, 2008 | Televison & Video
The dvd player will not eject the dvd
We once had 2 DVDs in the tray (thanks, kids). The tray would not open and had similar symptoms.
We eventually pulled/pried-open the tray (while it was attempting to open by itself, aka you could hear the try motor was activating.)
I'm sure a tech would cringe at this, but it did eventually pop open (with our aggressive help) - and all is well.
Good luck.
Jan 05, 2008 | GoVideo Go Video DVD/VCR Combo
RCA RTD210
you should never use a disc thats scratched inside yiour machine its most likely your dvd machine is having trouble reading your media the best way to solve this is to unplug your machine wait turn it back on keep pressing eject it should eject dont use that dvd disc again hope this solves your problem did for me ;
Jul 31, 2007 | RCA RTD210 System
Myron & Davis ADM170GY Car DVD Player Logo
Top Myron & Davis Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Joe Ball
Joe Ball
Are you a Myron & Davis Car Audio and Video Expert? Answer questions, earn points and help others
