Question about HEWLETT-PACKARD CP1025nw Laser Printer
Turn off sleep mode
Where is the setting
You just cannot turn the sleep moide off from this useless printer! I would expect HP to let its CUSTOMERS to decide whether they want to save the planet or get their print jobs done, because HP seemingly cannot make the printer to wake up from its coma when a new print job arrives.
Posted on May 22, 2016
    Problem Solver:
  • 13 Answers
Print a menu map from the control panel
Posted on Feb 10, 2015
My LG optimus keeps getting stuck in sleep mode. When I turn it on it seems fine but once it enters sleep mode it won't turn back on. I have to restart the phone to get a picture again. Any tips?
Is it ''sleep'' mode or ''Hibernate'' mode? If ''Hibernate'', then that is the problem. Turn off ''hibernate.'' If it is in fact just ''sleep'' mode, check to see if it is set for ''enter password to exit sleep'' _and_ you don't have a password set up... then either create a password or set it so that it does not require a password upon exiting sleep. Also, you can always resort to resetting everything to ''default'' settings. (This will not effect any data on the phone, and you can take your time setting all the settings ''just right'').
Jan 02, 2015 | LG Cell Phones
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Prostart 6 button in sleep mode
Sleep mode is a convenient power-saving feature used on both laptops and desktop computers. This feature powers down hard disks, monitors, wireless devices and any other power-consuming peripherals without turning the unit completely off and necessitating a reboot. Sleep mode can prevent battery drain if using a laptop or mobile device while away from the power supply. This mode is useful when quick access to a computer is needed, but can be irritating if the sleep mode takes a long time to come back from. It is simple to turn sleep mode off, based on the operating system being used.
Go to the "Start" button, then click on "Control Panel." In the control panel screen, click "System and Maintenance," then click on "Power Options." This brings you to the "Select a power plan" page. From the "Select a power plan" page, select the option that says "Change plan settings." This changes the settings on the currently selected plan. Select the "Change advanced power settings" option. Click "Sleep" and then click on "Sleep After" to expand it. If using a laptop or mobile PC, click "On battery" and "Plugged in," then select the "Never" option. This turns off sleep mode for both battery and AC use. If you are using a desktop computer, click "Setting," click the arrow and then click "Never" to turn off sleep mode. Click "OK," then click "Save changes" to save the modification. b> Turning Off Sleep Mode - Mac OS b> Click on the Apple logo at the upper left corner of the screen to open the menu and select the "System Preferences" option. From the "System Preferences" screen, click on "Energy Saver." If you are using a desktop, select "Power Adapter" in the top drop-down menu. In the second drop-down menu, select "Custom." Highlight the "Sleep" tab, then adjust the top slider to the far right, marked "Never." I f you wish the display to stay on, adjust the bottom slider to "Never." Click the red button on the upper left side of the "Energy Saver" screen. If you are using a mobile product or laptop, follow step 2 and select "Battery" from the top drop-down menu. Repeat step 3 to change the settings for battery use. Hope this helps.
Jan 09, 2013 | Computers & Internet
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
Laptop doesnt wake up after sleep mode activation
sound slike hard drive is going ...go into settings and turn off sleep mode and also set it to hard drive NEVER shuts off
Dec 11, 2009 | Computers & Internet
My machine is also set to sleep mode and cannot rcv. faxes!
Sleep mode does not affect the reception of faxe check receive settings instead
Aug 28, 2009 | Brother IntelliFAX 2800 Laser Fax
Monitor goes into Sleep Mode immediatly upon turning on computer
I have a LCD panel it is connect to to the LCD. I need to change a setting on the computer to make it stop going into sleep mode, however, now that it's in sleep mode, how do I get out of that so I can make the change?
Jan 09, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Emachine sleep mode
Try going into your cmos settings at system boot (usually hitting delete or F keys, funtion keys as your computer first turns on). Check to to see the boot sequence and look for sleep mode settings. If there isnt an option there, boot your system in safe mode and check through your windows settings for sleep mode settings.
Dec 18, 2008 | E-Machines emachines (emachinees) CD-ROM...
Turn off sleep mode, It causes prob. turning on programs to use computer
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
Oct 13, 2008 | E-Machines eMachines Desktop PC
Sleep mode
Press Menu/Set, 1, 6, 2 (2. Sleep Time should be displayed) Simultaneously press Start and Options at the same time Press Menu/Set Press Stop Exit This will turn the sleep mode off. The new setting will apply after the next time the machine copies, prints or is turned off and on.
Sep 13, 2006 | Brother IntelliFax-2820 Laser Fax
HEWLETT-PACKARD CP1025nw Laser Printer Logo
47 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
