Question about Fein WSG 14-125 5-inch Angle Grinder with Slide Switch
Fein angle grindse slide switch sticking
Unable to push slide switch forward to start the angle grinder
How to Change a angle grinder disc
My angle grinder came with a special wrench to take off the disk. I have a small button to push that locks the shaft. I push it gently with it UNPLUGGED while turn the grinding wheel by hand till it locks. Then I use the wrench to undo the "nut" that holds the grinding wheel on.
Sep 27, 2014 | Saws
I am about to pull out the armature and there is a shield under the cooling fan (which is conected to the armature) that should slide out with the armature. It is real tight and I do not want to pry to...
Yes it should pull out with the armature. The plate can only be removed after you remove the nut and gear on the end of the armature. Make sure your brushes are pulled out first or they can hang up on the bearing at the other end of the armature which may be what is happening in your case.
Jul 11, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
How do you remove and release the quick grinder pad?
There is a button at the front of the grinder usually black or red, depress it lightly and rotate the wheel (unplug grinder please) wait until you feel it fall into spot, depress tightly and hold then turn wheel and unscrew to replace pad. Reverse to reassemble.Good Luck....
Apr 21, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
Dear Sir, We have few Metabo grinder I have some doubt about Dead man switch can you explain me what is the function of dead man switch. Regards Nitin
Hello, a dead man switch functions in this manner. As long as you hold the switch down the grinder functions, and as you know when you release it the grinder stops. This is a good safety feature in that if you drop the grinder of lose control of it, if the grinder stays running it could cause a lot of damage to material or your body. The switch can seem to be a pain when having to hold it down all the time, but it is a safety feature that can actually save your life in the case of you losing control of the unit.
Mar 13, 2011 | Metabo W10 150Quick Angle Grinder W10 150...
I have mac allister angle grinder the problem when switch on the geinder start and suddenly stop and showing over loaded
Hi ibychackoja, It is the problem of the carbon brass replace it with a new with the identical size of the old one. Feel free to ask whatever the results.
Regards; VOTIT
Dec 03, 2010 | Makita Angle Grinder
Fein multimaster 250Q quick release not working. Spring action worked at first when lever was fully pushed (180 degrees) the tool holder would not release and the spring action was gone. How doe I fix...
either your not holding the pin in the right place or your multimaster was used with the pin in the wrong place to begin with and the lever was forced down causing the holding mech. to wear out.
Oct 21, 2010 | Fein FMM250 Start Multimaster Oscillating...
A friend who bought a multimaster less than a year ago has had his start a loud 'clattering', dry, noise, and the gearbox started to get hot. The output shaft now has about the same amount of slop as the...
Fein is an excellent tool and has an excellent warranty that will be void the moment you open the gearbox. I do not recommend this action. Fein is quick and responsive, especially for a less than one year issue. Farmerbear at FixYa.com
Sep 30, 2010 | Fein Multimaster Rs - Msxe 636 - 2 Rs
I don't know how to change the grinding blade on my makita angle grinder.
There is a nut that you release from the middle of the grinder wheel, (grinder blade)
This nut is flat and has four holes in it.
You will see you are providing a spanner wrench to remove this nut. The wrenches' actual name is Lock Nut Wrench. It has a U shaped end with two pins sticking out. On on each side of the U shape.
The pins are inserted into the holes in the flat lock nut, located in the middle of the grinding wheel. The wrench is laid flat against the grinding wheel, with the two pins of the wrench going into any two holes of the nut.
At the top of the Makita grinder you will see a Black button. The button is pushed down to keep the grinding wheel from spinning. Holds the grinding wheel in place, as you turn the lock nut loose. When you release the button, a spring inside pushes the button back up out of the way.
As you view the Makita grinder, Release Button towards the Back, grinding wheel towards you, the nut is turned to the LEFT, to loosen. It is a Left threaded nut.
The grinding wheel spins to the Right. Using a left threaded nut insures that the nut will stay tight, due to the direction the grinding wheel spins.
Oct 01, 2009 | Makita Usa Inc 9557PB 4 1/2" Angle Grinder
Drill and grinder only work upside down
The only time I have encountered this problem is when the field coil is loose in the motor housing, or one or more of the leads has come loose. By tipping the unit back the coil slides to the rear and makes contact. Then contact breaks when the tool in tipped forward.
Apr 28, 2009 | Metabo 600242420 BHE22 7/8" SDS-plus...
Fein WSG 14-125 5-inch Angle Grinder with Slide Switch Logo
27 people viewed this question
Top Fein Saws Experts
Tom Chichester
ray gallant
Are you a Fein Saw Expert? Answer questions, earn points and help others
