Vokera fault code A04
Fault showing A04
How do I fix an A04 display code?
It either has a short in the wiring or may need a new PCB
Nov 30, 2011 | Comfort Zone CZ1500WC Infra-Red...
What is code A04
Try pushing up, down and enter at the same time. If that does not work unplug and try again this should reset if the PCB is good.
Nov 21, 2011 | Comfort Zone CZ1500WC Infra-Red...
Cod. error a04 on the display
Appliances fault A04 has different meanings depending on the type of appliance. Please see below for further detauls:
Also see our video section for help.
Error: A04,
Machine: Dishwasher,
Type: EV02 Module,
Fault: The selected temperature was not reached within a given time.Check thermistor and heater
Error: A04,
Type: Standard Module + FDW70 + FDW75,
Fault: Heating fault.Check thermistor and associated wiring
Hope helps.
May 02, 2011 | Dishwashers
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
Entered code says wait 1 hour
When you add an IDC-A09 changer to a pre-2004 car, you should not need to enter any code, it should just plug and play. If you have added an IDC-A09 changer to a post 2004 car the you have probably got the wrong changer. Post 2004 cars *usually* need the IDC-A04 changer, which looks identical.
The IDC-A04 uses CAN-bus while the IDC-A09 uses VAN-bus wiring. The two are not interchangable.
Apr 03, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
I have a vokera unica 28 which pulses when firing
your fan may need attension fan runs after boiler shuts down is normal on some Vokera,s too clear fumes out the flue 2mins approx
Oct 04, 2009 | Water Heaters
I have a vokera linea 7 boiler and i get a 01 error code
01 is ignition failure . flame sensor or blocked pilot
Jan 18, 2018 | Heating & Cooling
Vokera linea combiboiler error code CO
It's got nothing to do with carbon monoxide. CO means the boiler is in combustion test mode, that's all (and in this case -- long since fixed, I imagine, but other people will no doubt find this page in the future -- failing). Vokera could probably have made this clearer, but hey.
Dec 23, 2008 | Water Heaters
DE73 A04 Error code
you may have a bad heating element..or temperature sensor the water temperture is not getting hot enough to let the dishwasher run. you my reset it and try running the water in the sink until it reaches hot ... then try stating the dishwasher...let me know if this helps
Aug 28, 2007 | Indesit 24 in. DE73 Evolution...
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
