Question about INTEX Sand Filter Pump
Sand filter overheats
It'll run for about 30 min, then it overheats and shuts off. After I turn it off and let it sit for awhile it comes back on
  • 2,760 Answers
Your pump shaft must be tight to turn , this could be caused by improper pump off season storage/or normal worn out or your sand charge is getting thru the filter , either one spells disaster for pump
Posted on Jan 08, 2015
92 bonneville, keeps shutting off and after 10 - 20 mins will crank back up. But after riding for so long it will shut off when coasting or coming to a stop. Or not crank up after driving for awhile......
this is not a problem to change fuel filter, you have to know if there is fuel pressure and spark from the ignition coil , air filter clug
air,fuel,fire tree things to have to get it running
Aug 02, 2013 | Cars & Trucks
Car runs fine about 30 mins then dies
My 1986 caddy does the same thing. Did you have any luck fixing yours?
Mike
Jun 10, 2012 | 1986 Cadillac DeVille
Laptop shuts off afer 5 minutes
Sounds like your laptop might be overheating. Does it reboot successfully immediately after is shuts down after 5 minutes or does it have to sit awhile before it reboots successfully?
If you can't boot it right back up after it shuts down, then it is definitely running hot and will only boot back up successfully after it sits awhile to cool off.
Things that cause it to run hot:
1) Dust... Dust clogged in the vents, fans and around the cpu and heat sink.
2) A Fan is not working
3) The Thermal Paste around the CPU and Heat Sink has dried up or is too thin to keep the unit cool.
For the best results you'll have to take the laptop apart to remedy the situation especially if you need to get to the Fan, CPU or Heat Sink.
You can try a can of compressed air and blow out the vents and fan area, that might work for a while but you'll be blowing the dust in. It's best to take it apart and blow the dust out.
Apr 02, 2012 | Toshiba Computers & Internet
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
After playing the wii for about 30 min it will shut off. If you let it sit for awhile it will turn back on however 30 min is usually the longest you can play
Sounds like it is overheating, which is an internal fan problem. Ninitendo should fix this for you for free, please call them at:
1-800-255-3700
Sep 09, 2010 | Nintendo Wii Console
My Hoover runs for a few minutes and shuts off.
It's possible the thermal reset is defective. It shuts the motor off if it gets hot. Remove the bag door and take the bag off, remove both filters and then turn the vacuum on, just leave it sit there with the motor running. This eliminates the bag or filters causing any airflow resistance. If it still shuts off after a few minutes it's likely the thermal reset is bad. Some vacuums have an external thermal reset button which can be replaced if necessary but on your model it is built into the motor and you must replace the motor. If the motor runs fine put the bag and the filter under the bag back in - (make sure the filter is clean and not restricting airflow) put the bag cover on then turn it on again. If it overheats and shuts off then you may have a clog on there somewhere restricting the airflow. If so check the power nozzle area, the hose coming from the power nozzle, the extension hose and wands for clogs or restrictions.
Sep 22, 2017 | Hoover U6426-900 Bagged Upright Vacuum
INTEX Sand Filter Pump Logo
125 people viewed this question
Top Intex Garden Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
Tom Chichester
Are you an Intex Garden Expert? Answer questions, earn points and help others
