Question about Miele Incognito G658 SCVi Built-in Dishwasher
Fault 11 - inlet or outlet blockage
For the last 3 dishwasher washes our Miele G1270 SCVI has been making a bad noise when the water was filling at the beginning of the cyce - liek something was blocking the inlet - but it still worked . The last wash it started bleeping mid cycle - the message 'F11 - inlet or oulet problem' came up . the machine stopped working and it was full of dirty water when opened . Can you please advise us what to do next
Many Thanks
  • 132 Answers
THIS TYPE OF M/C PERMIT WATER TO FILL IN LONG TIME IF THE PRESSUR IS LOW
I THINK AFTER ABOUT 3 MINUIT YOU CAN OPEN THE DOOR AND CHECK OF LEVEL OF WATER TO ASSURE IS LEVEL OF WATER IS SUFFISUNT OR NOT
Posted on Jun 14, 2009
How do I fix a Miele G2470 SCVi with an intake/drain fault
Look for item(s) blocking the drain, inside bottom, and remove them.
May 24, 2014 | Miele Dishwashers
Miele G863 SCVi All lights blink at the end and it doesn't dry
Check the web for,
2011-11-25_043923_g600__800_miele_service_manual.pdf
I found that PDF while working on fixing my Miele dishwasher and found it more helpful then most advice on the web.
Dec 30, 2012 | Miele Dishwashers
Miele dishwasher will not drain (G 2270 SCVI)
you need to replace the non return valve.
May 27, 2012 | Miele Dishwashers
Hello. My dishwasher (Miele G 579 SC) does not fill water enough. When filling is done I must fill manually with a bucket to get water to a sufficient level. What might be the problem? Kind regards...
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 05, 2011 | Miele Dishwashers
Have Miele G653 SCVi plus. We have inlet/drain flashing red light
Sounds like something is caught in th drain pump as the unit has to drain first before anything else happens. Remove the filter and the non return valve which is under the clip in the sump of the unit. In the manual it shows you this. Make sure the drain pump is free of any foreign particles like broken glass. Then start the unit again so it goes to drain without the non return valve in place. This will then throw out any foreign particles as well.
or it could be the drain pump is activated all the time which is the noise you hear as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Feb 22, 2010 | Miele 24 in. G653 SCVi Plus Built-In...
Inlet/outlet light keeps flashing on G641 dishwasher - have checked filter and cleared debris. Just completed a wash but dishes not washed or rinsed adequately. Anything else I can check before requesting...
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely. See what part of the cycle the unit lights up the fault. If it happens at the very start it is the drain. If it drains ok then fails it is the inlet. If it fails after that it could be any number of things.
Hope this helps.
Jan 26, 2010 | Miele 24 in. Novotronic G641 Plus Built-In...
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Miele dish washer
I have a miele G 643 SCVI Ingognito the re-0cccurring prob is the the drain/intake light comes on quite frequently I have to cylcle the on/off switch twice to clear the fault. I have check the drain line several time w/o any obvious findings what's next
Feb 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher won't fill - inlet/outlet light comkes on
check no water in the base either by taking front bottom panel off or tilting back. if water runs out, means you have a leak. could also be inlet valve open circuit
Apr 10, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele Incognito G658 SCVi Built-in Dishwasher Logo
652 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
