Question about Euro-Pro Ninja Kitchen System 1100 - Model BL700
How do I disassemble a Ninja 100 pitcher handle
I need to clean it. I have removed the 2 screws at the base of the handle but the handle will not come off. I hate to force it and break it.
The black plastic screw on bottom of the pitcher is stuck on the base. We can't seem to get it off. Have any hints
Put the pitcher in the freezer for an hour, boil water in a pan bigger than the base of the pitcher, take the pitcher out of the freezer and stick just the base in the hot water up to the top edge of the base.. Remove it after about 15 seconds and have someone with gloves on screw the base off the pitcher
Aug 20, 2015 | Blenders
How to remove splash guard from base
Good evening
it is difficult to take the bottom things from each other. The blenders I know are screwed to each other,
all the best
kolbrun
Feb 01, 2015 | Euro-Pro Ninja Master Prep Blender and...
The power light on the Ninja Blender flashes and will not turn on.
Make sure the pitcher lid is assembled properly aligning the arrow on the lid with the arrow on the handle. Press down firmly on the handle until you hear a slight click to ensure it is fully engaged. The Ninja will not run if the lid is not assembled correctly & the handle is not fully engaged.
Sep 28, 2014 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Power light is blinking and the blender will not work
Align the arrows on lid and handle, and latch it down before you put the pitcher on the base and spinning it to lock it in.
Mar 18, 2014 | Euro-Pro Ninja Nj600 1000 Watt Xl...
Ninja lid removal
your pushing the handle release button on the lid, swinging the handle straight up and pulling on the handle straight up?
see page ten figure 6: http://www.ninjakitchen.com/manual/NJ600_30_IB_ENG_100527.pdf
Nov 10, 2013 | As Seen On TV Ninja Professional Blender
Ninja Kitcen System 1100 gear shaft cracked in half.
hi i also need the gear shaft for my ninja pro system blender and i finially found a website where i can at least buy the whole pitcher the website is www.ninjakitchen.com the pitcher is 34.95 but at least i will finially be back up and running.i hope this helps...happy new year.....jennifer
Oct 08, 2012 | NINJA Kitchen System 1100 - As Seen On...
Hi. We have a Cuisinart smart power blender. When we mix drinks, there is some sort of black residue seeping into the glass pitcher. Do you know what is causing that?
This can be coming from discoloration and/or food acting on the rubber gasket. Be sure to take the pitcher apart, removing, the screw on base cap, the blade mechanism,and the gasket to clean your blender after each use. Acids and liquids can act on the rubber causing a discoloration and this will seep into your pitcher. This should take care of your problem. If it does, please come back to Fixya and rate my solution!
Jul 14, 2011 | Cuisinart Blenders
My ninja blender is brand new and i plugged it in and it doesn't start. what do i do?
There's an arrow on the lid and an arrow on the handle and they have to line up and point towards each other. When you lock the lid down it pushes a pin inside the handle which in turn pushes a swith inside the base of the blender that tells it that everything is in place and that its safe to use. Now its ready to use
Apr 02, 2011 | Blenders
My blender base has become discoloured with a sort of green mouldy streaks, how do i clean
If you remove the blinder base where the blades are you can put it all in the dishwasher. To do this grab the handle on the pitcher then unscrew the plastic base from the glass. make sure that you look how it comes apart first. then put in the dishwasher to clean. Then reassemble the way you took apart.
Jan 11, 2011 | Oster 12-Speed Brushed Nickel Blender...
Unable to screw base off to clean
Leave the pitcher on the it's base and twist in the counter clock wise direction.
Nov 02, 2009 | Back to Basics Smoothie Elite Work Top...
Euro-Pro Ninja Kitchen System 1100 - Model BL700 Logo
94 people viewed this question
Top Euro-Pro Blenders Experts
spy1309
Tom Chichester
Kolbrun...
Are you an Euro-Pro Blender Expert? Answer questions, earn points and help others
